AC Problem
Old Aug 17, 2003 | 01:15 AM
Clancy109's Avatar
Clancy109
Question AC Problem
The AC, in fact all air, is coming out through the defrost vents. This happened just after towing my 5th wheel 2 1/2 hours. Vacuum hose?
Old Aug 17, 2003 | 07:28 AM
powerstroker250's Avatar
powerstroker250
AC Problem
Loose vacuum hose or the vacuum pump itself. Maybe an electrical connection.
Old Aug 17, 2003 | 08:04 AM
alanscott's Avatar
alanscott
AC Problem
That where Ford defaults the air flow when there is a vacuum problem.
Old Aug 17, 2003 | 10:25 PM
riverbedjed's Avatar
riverbedjed
AC Problem
Mine has the same minor problem, I would say its the vacuum pump or a leak in it somewhere. I'm going to replace mine soon. I think it affects your esof to (electronic shift on the fly). Mine stays on defrost for about 30 seconds and then goes pack to the panel. Good luck fixing it clancy
Ken
