Rocker arm geometry
Old Jun 19, 2016 | 09:45 AM
XTfx4's Avatar
XTfx4
Rocker arm geometry
I know there are threads on this topic, have read them and they helped a lot for me to understand the whole concept !!!! Now that I do I'm trying to dial it in to proceed with my build. Using stock arms with each scenario: 9.5 push rod 3/4 turn of pre load and .180 cold lash.
9.560 push rod 1 3/8 turn preload and .106 cold lash.
9.560 push rod w/ .020 shim 1turn of preload and .156 cold lash. ?? Which one?? Also the sweep pattern seems to favor the exhaust side on all scenarios. Except for the 9.5 push rod is slightly closer to center. Kind of leaning toward the 9.5 for geometry reasons and the preload is within range. But is the cold lash too big? I guess what is more important pre load , cold lash , or geometry ?? Has any one ever milled the the rocker arm fulcrum to help with geometry ??? Thanks for any help ?!!!'
Old Jun 19, 2016 | 10:11 AM
XTfx4's Avatar
XTfx4
Engine info
Sorry left out some important info. The engine in question is a 400 with kb Pistons , lunati rv cam. Thanks
tomcasino
Dec 27, 2017 03:26 PM
akblackfoot
Jun 23, 2017 09:47 AM
huntke
Apr 9, 2012 02:10 PM
V8orBUST
Dec 18, 2011 06:26 PM
jcahicks
17
Mar 8, 2011 09:51 PM
