Sponsored by: Kumho
E-Brake Adaptation
Old Jun 19, 2016 | 01:26 AM
Jim Egan's Avatar
Jim Egan
E-Brake Adaptation
Let me begin by establishing my credibility, I own a 49 F-1, a 93 F-250 4x4 and a 1950 F-6; but, I have a problem. This may be blasphemy to some of your ears, I have a 1948 Dodge COE on a 1977 Dodge M500 M/H chassis in which I'm trying to install a 1996 Cummins 5.9 diesel engine. My problem is with the e-brake setup. The M/H came with a 440/727 setup with the e-brake attached to the 727 transmission output shaft (part of the casting). The M/H chassis has a Dana/Spicer 70HD which has no provision for an e-brake; so I'm left with trying to fabricate an e-brake for the drive shaft. The driveshaft for the Cummins 47H transmission must "slip" in/out of the transmission tail-shaft. I have been told that Ford had/has a driveshaft e-brake that attaches at the differential end of the drive shaft on E-450/550 trucks. If this is true I might be able to adapt the Ford unit to my project (48 Dodge COE w/ 5.9 Cummins on a Dodge M500 chassis). Can any of you confirm the location of the Ford e-brake and provide the measurements for the attaching studs? Any help appreciated. Jim
L. Horton
Jan 29, 2017 07:10 AM
Oakroadjoe
Ford Truck Parts for Sale
Nov 1, 2015 05:13 PM
cyrus
Oct 31, 2012 11:15 AM
clhart426
May 17, 2011 03:19 PM
