Driptight air compressor
It seems like Ingersoll-Rand's outdoor kits are overkill. I think they are some sort of hood? I have seen plenty of other compressors outside.
What are the real world experiences here?
Birken
You may be able to see some definitions at the Grainger website: http://www.grainger.com/
Will it be gas operated? If not, even an old and gutted refrigerator is better than nothing. There are no refrigerant lines going through the door, so you could install a vent at the top and bottom for fresh air and keep moisture down.
Rubbermaid makes those compost containers now for about $25 and would at least conceal it from most prying eyes.
Talk with you guys later..
Hi Eric!!!
I was hoping somebody who worked at a place that has one of these setups would chip in. I did see a weatherproofing kit in I-R somewhere but I can't find it now.
Birken
If you mount yours outside you may want to build a sheet metal hood for it to keep the direct and wind driven rain off.
As far as sitting the compressor outside, I would also suggest an enclosure. A solid roof and louvered walls would provide adequate weather protection with good ventilation. Pressure treated wood louvers or even old shutters will look respectable.
You mentioned summer heat is a consideration. Are freezing temperatures in winter also a concern? The condensation inside the tank & lines will freeze & this may also cause trouble. You can minimize ice troubles by making sure there are no points in any piping where water will collect. Drain the water out of the tank whenever it's warm enough to do so. If you use a filter / regulator / lubricator setup, put that inside the shop.
The compressor oil my thicken too much in cold temperatures, too.
Also you may need to be considerate of yor neighbors. If the tank cools down at night, the pressure will drop & it may kick on if the power is left on (it is VERY easy to forget to kill the power at night). I have a compressor inside my garage, but I would be really unhappy if a neighbor's rig kicked on at 3:30 am.
Cheers,
Eric
This is for my fire department, I am doing the installation. The compressor will be on constantly in order to supply air to vehicles that have systems that leak. Don't lecture me on fixing the air brake systems please, leakage over a day is perfectly acceptable.
So the compressor will run from time to time. It is going to be out back because that is the only place there is room, and to keep the noise away from the barracks especially.The compressor will be a 5hp 2 stage vertical unit.
I installed the line last week, it is underground and it is pitched down to the shop where I have a drip leg and a u-shaped drain buried with a small riser and ball valve to blow off water there. The frost does not get into the ground here. The air does freeze but only at night. I intend to install an automatic drain on the compressor and use synthetic oil or whatever the manufacturer gives the best warranty on.
Otherwise there should be no problems, inside the building is always heated and that is where I will put the rest of the goodies.
When I do construction projects I don't make up anything myself (within reason) I just copy other professional installations. That is why I asked, because I see lots of other compressors sitting outside completely exposed. I am not opposed to making a tin hat for whatever needs it to keep the water off. But I would prefer to buy it already that way.
Birken
Why do you want a two stage model?
