A/C question
Old Jun 16, 2016 | 08:25 PM
fordguy98's Avatar
fordguy98
Originally Posted by Heliguy
If youre going to 134 it its best to replace the condenser too. A 134 condenser has more cooling area and works much better than the OE one designed for R12. I did a kit from Classic Auto Air which included everything except the evaporator for around $800. Works great so far.
I wouldnt mind paying 800 for that kit since it'd give me cooler air but I can't afford something like that because I'm gonna be sending my truck off before to long to get it painted. If it wasn't for that I'd go ahead and buy the kit to get the air running
Old Jun 16, 2016 | 09:23 PM
Heliguy's Avatar
Heliguy
Originally Posted by monkey-1
What all does that kit include?
It comes with everything except the evaporator. Ford OEM Factory Air Conditioning Parts & Restoration Services
the '73 - '79 kit isnt on their website but they have one and it fits perfectly.
Old Jun 16, 2016 | 11:08 PM
kegger66's Avatar
kegger66
Couple other options linked in this thread:
https://www.ford-trucks.com/forums/1...to-sanden.html
Old Jun 17, 2016 | 07:59 AM
46Whizzer's Avatar
46Whizzer
Originally Posted by fordguy98
About 90 miles north east of Lubbock. A little town of 200. It'd be awesome to have some help on this project! Lol
Bummer. I'm in central texas, about 30 miles outside of the DFW mess. I think you are a bit out of range.
What sort of condition is the current a/c system in?
Are all the parts still there and is the compressor free?
Old Jun 17, 2016 | 08:23 AM
fordguy98's Avatar
fordguy98
I did just discover this bad spot on a small line going from the coil to the condenser
The compressor turns when I turn the control switch on and other then that one bad spot in that small line everything looks intact and from what I can tell nothing is missing
Old Jun 17, 2016 | 08:39 AM
kegger66's Avatar
kegger66
I had the same kink in my liquid line, you'll need to replace that (Fellow FTEr may have one for sale or you can get a replacement made at an A/C shop). Other than that you might be able to get away with a flush of the whole system and a charge.
Old Jun 17, 2016 | 08:51 AM
fordguy98's Avatar
fordguy98
Since a common everyday Joe can't buy r12 anymore without a license could I get by if I bought one of those adapters for r12 to r134 from a parts store? With after I flush the system of course.
Old Jun 17, 2016 | 09:09 AM
benbuilder's Avatar
benbuilder
HoustonDave says:
"you can try purging the system by pumping a lot of alcohol through it, blowing it as dry as possible, then filling it"
Is there a process for this? I am having an A/C guy come to my house for some ac repair, I am hoping he can remove the r-12, then purge the system for me as I am taking the ac from a parts truck into my restoration project.
Old Jun 17, 2016 | 09:57 AM
kegger66's Avatar
kegger66
I think as long as the system has been closed (not unhooked where the elements have gotten in there - a flush, recharge with R134 (and PAG Oil) should give you conditioned air. There might be some o-rings you'll need to replace either because they are old or don't work well with R134 (read:leaks). Most folks will tell you that R134 in an R12 system doesn't produce as cold air as the old R12 did (expectations) but it'll be better than hot!
You might search in FTE/google/youtube for purging methods to see how it's done. I think its pretty straightforward if you have/borrow the right gear.
Old Jun 17, 2016 | 10:01 AM
benbuilder's Avatar
benbuilder
Thanks. I will do some homework. Mine has been closed, so I think I should be ok.
Old Jun 17, 2016 | 10:40 AM
kegger66's Avatar
kegger66
Fordguy98 - What's this?
Old Aug 24, 2016 | 03:52 PM
fordguy98's Avatar
fordguy98
My wires going to and from the brain box. Sorry for the late reply
Old Aug 24, 2016 | 03:53 PM
  #28
fordguy98's Avatar
fordguy98
I didn't do that it was like that when I got the truck
Old Aug 24, 2016 | 04:01 PM
  #29
fordguy98's Avatar
fordguy98
Or no I'm sorry those are the wires going to my trailer plug. I'm not sure why they where putbon like that
tkerkela
Sep 16, 2016 12:25 PM
Vic93
Aug 1, 2013 05:55 PM
webly
1983 - 2012 Ranger & B-Series
15
Jul 12, 2009 12:42 AM
slychicken37
Apr 18, 2006 06:51 PM
55-willys
Aug 4, 2003 11:32 PM
