Rear fuel tank returning fuel to front
Okay so just put in new front tank and new rear 38 gal tank. Also put in a new tank selector valve.
Ran the front tank down to fumes, filled the rear and switched. Thought my gauge was messed up as I only drove 45 miles and my gauge was down past 3/4. Shouldn't do that even on 19 gal tank. Switched tanks and front said full.
Long story short, I pulled my dash apart to find nothing. Went to get fuel and I was able to put 20 gal in the rear tank that should have only been down 3 at the most.
Question is if the return for the rear tank is plugged will it automatically return to the other tank? It's a bran new OEM for selector valve and I can hear it switch as soon as you flip the dash switch.
Well the valve is new, only been on maybe a week. I checked the lines and they are connected correctly.
I disconnected the rear return at the valve and blew air back to the tank thinking maybe it was plugged. I then blew air back from the return by the engine bay to the selector valve and it came out of the port that I had disconnected. We will see what happens now I guess.
Disconnect both tank return lines from the valve and back-blow the return from the engine again. Make sure air is only coming out of the rear return port on the selector, not the front port at the same time. Throw the switch to FRONT and check the same thing (should go to front return only). The return side might somehow allowing fuel to go to both.
Now my toe in is off and eating my front tires. Rotated them yesterday so looks like I will be making an appointment at the alignment shop.
agoodfellow92
07-15-2019 11:44 AM
tkisling
12-25-2013 09:47 AM
lud04X
12-03-2011 09:58 PM
AaronOregon
09-16-2009 01:03 PM
