Help Stranded!
Old Jun 14, 2016 | 06:26 PM
rlansdon's Avatar
rlansdon
Help Stranded!
Truck started running really rough, lost power. Pulled over and found oil running out from the area near the inspection plate.. Any ideas!?
To the right of the gear..
Old Jun 14, 2016 | 06:40 PM
fuzzy1626's Avatar
fuzzy1626
Are you sure it's not fuel washing down that side of engine?
Old Jun 14, 2016 | 06:46 PM
bashby's Avatar
bashby
Yep, fuel leaks look like oil leaks after the fuel mid s with that thin layer of oil that has accumulated over the years. Pull your air cleaner and look in the valley for a leak. There is a drain in rhe back of the valley pan that dumps at the rear of the engine, right where it meets up with the trans, so it runs down from there.
Old Jun 14, 2016 | 06:54 PM
rlansdon's Avatar
rlansdon
While there is some fuel in the valley, my dipstick isn't even registering oil.. Any other ideas? I don't see any oil in the valley.
Old Jun 14, 2016 | 07:09 PM
bashby's Avatar
bashby
Turbo or NA?
Old Jun 14, 2016 | 07:13 PM
rlansdon's Avatar
rlansdon
Turbo or NA?
Do you mean check the turbo? I don't understand
Old Jun 14, 2016 | 07:53 PM
bashby's Avatar
bashby
I mean do you have a turbo or not.
Old Jun 14, 2016 | 08:17 PM
rlansdon's Avatar
rlansdon
Sorry. Yes I have a turbo. I just got the truck home. Had to put a gallon of oil in it. It was pouring out from the same location again
Old Jun 14, 2016 | 08:19 PM
bashby's Avatar
bashby
I am only asking because if you have w turbo there are more things that
can leak.
You do have a 7.3 IDI and not a powerstroke, right?
Old Jun 14, 2016 | 09:42 PM
AKHunter93's Avatar
AKHunter93
Does it leak even when the engine is off?
Awhile back I had a rather significant oil leak that would drip down over the starter as well, but it was just the passenger side valve cover that had come loose.
Old Jun 14, 2016 | 11:10 PM
genscripter's Avatar
genscripter
On a side note, please tell me you weren't driving around without a flywheel cover?
That looks more like diesel to me.
Old Jun 15, 2016 | 06:39 PM
madpogue's Avatar
madpogue
Is this the 1997 truck in your profile? It's, er, not an IDI. Best to ask a mod to move this thread.
If you have fuel in the valley and are that low on oil, you're probably leaking both, and they're mixing as they drizzle down, which would explain the appearance.
thebig350
18
Jun 25, 2010 10:48 AM
Bubba828
Jan 27, 2009 08:52 AM
63DH8
Nov 20, 2008 10:56 PM
yelog60
Sep 25, 2008 10:45 PM
poorfatkid
27
Dec 15, 2007 10:15 AM
