Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Possible ac compressor leaking 01 escape
Old Jun 14, 2016 | 05:43 PM
adamant's Avatar
adamant
Possible ac leaking. What is the alternative besides replacement?
Old Jun 15, 2016 | 08:09 AM
wptski's Avatar
wptski
There isn't much oil in a A/C system, if one sees oil, your refrigerant is gone or very low. Does your A/C work? The common place for a compressor to leak is at the shaft seal and the pulley will spatter the oil nearby, did you see that?
Old Jun 15, 2016 | 08:17 AM
adamant's Avatar
adamant
Ac still blows cold. No. It's not splattered. It's a yellow substance thats oily. I had my system charged last week and added a sealant . The escape was sitting for 3 yrs.Thinking maybe the sealant..
Old Jun 15, 2016 | 10:32 AM
projectSHO89's Avatar
projectSHO89
Clean it off thoroughly (brake parts cleaner works) so you can actually see if its the oil from the AC dye or motor oil or other from the oil filter or somewhere else. The photos are not distinct enough to determine.
You could hit the oil slick with a black light and see if it lights up, that would indicate fluorescent dye.
Badkisson
2004 - 2008 F150
Apr 3, 2018 09:33 PM
cougarman001
Sep 13, 2012 06:06 PM
Spades
Sep 13, 2007 06:10 AM
HENDEL
Aug 4, 2007 08:41 PM
