thrpttle body
Old Aug 16, 2003 | 06:28 PM
Black Ford XLT's Avatar
Black Ford XLT
thrpttle body
Whats the largest throttle body i can install with out doing any otherwork( intake) stock application 1992 bronco 351 . 51 mm 62 mm?all replies appreciated. thanks TR
Old Aug 22, 2003 | 01:39 PM
fordin K's Avatar
fordin K
thrpttle body
hey you should try talking to some Mustang fans, they regularly
swap TB's to bigger sizes, I'm sure they have a whole chart to show info..... good luck
Old Aug 22, 2003 | 05:27 PM
Cloim's Avatar
Cloim
thrpttle body
fordin K:
Good idea, except they use single throttle bodies, and most trucks have duals.
Black Ford XLT:
I noticed, while looking at edelbrock intakes, that they have two sizes of throttle bodies. 56 and 61 mm. They recomend the 56 for their truck intakes and state that the 61 mm tb requires port matching of the intake.
So I'm guessing, but not certain, that 56 mm is probably the limit.
Old Aug 22, 2003 | 10:52 PM
fordeverpower's Avatar
fordeverpower
thrpttle body
If you are even going to mess with it go bigger.
Old Aug 24, 2003 | 10:02 PM
drewcoolness99's Avatar
drewcoolness99
thrpttle body
port matching isn't hard to do
http://www.fordmuscle.com
then go to tech articles and then heads and porting stock heads
it explains the matching
the basic concept is liek put white paint on the big side and the put the 2 together then grind out everywhere th white pain isn't on the lil sidel
