1990 f150
Old Jun 5, 2016 | 03:11 PM
Landrith101's Avatar
Landrith101
1990 f150
I currently have P235/75r15 on a stock 2wd F150, if I level it out using a 2in spacer will I be ale to fit 31x10.50's
Old Apr 27, 2021 | 05:40 PM
Shawn Owens's Avatar
Shawn Owens
i have a factory 1990 f150 4x4 i have 31/10.50/15 on factory rims the only issue i have with the tires is that they rub so if you put the 2 in wheel spacers you should have no issues with any rubbing and you shouldnt need to put a lift on it mine has no lift
Old Apr 28, 2021 | 08:21 AM
rla2005's Avatar
rla2005
Your issue is getting the front end realigned properly with those spacers. The Twin I-Beam front end on these trucks are not easy to lift/lower without adjustable bushings to correct the camber/caster.
Old Apr 29, 2021 | 09:34 PM
TexasGuy001's Avatar
TexasGuy001
You can run 31 10.50 with no lift. For raising or leveling the front, I suggest leveling coils that raise the front about 2 inches or slightly less. Anything more than that and you need drop brackets for the I beams. Suggest new coils over spacers.
96 Ford Flareside
2015 - 2020 F150
Jan 14, 2014 08:13 PM
