Shudder/Vibrations
Old Jun 6, 2016 | 12:50 PM
r2millers's Avatar
r2millers
The egr valve is simply a one way valve that can get plugged up but really hard to go bad.
I bet you didn't change the egr vacuum elbow, back behind the pass side valve cover?
You did say you changed vacuum hoses but that's usually where the leak occurs. Many times it will prompt a P0299 lean code.
Old Jun 6, 2016 | 01:10 PM
Fernie_Wan_Kenobi's Avatar
Fernie_Wan_Kenobi
You're right I didn't get at that elbow. I'll get that as well when I buy the sensor. But just to make sure.
Is DPFE just another name for the egr sensor?
Old Jun 6, 2016 | 01:11 PM
Action410's Avatar
Action410
Originally Posted by Fernie_Wan_Kenobi
It says egr valve sensor for my car. I changed the actual valve but not the sensor.
Is it the same thing?
The valve and the sensor for the valve are 2 different parts.
The signal to the computer is sent by the sensor.
>>>>>>>>>>>Action
Old Jun 6, 2016 | 01:12 PM
Action410's Avatar
Action410
It is the type of EGR system.
DPFE = Differential Pressure Feedback EGR
>>>>>>>>>>>Action
Old Jun 6, 2016 | 01:15 PM
Fernie_Wan_Kenobi
>>>>>>>>>>>Action
I should have worded that differently I mean egr sensor and dpfe sensor. Different parts?
Old Jun 6, 2016 | 02:01 PM
Action410's Avatar
Action410
DPFE sensor senses the pressure differential on both sides of the valve. This difference determines how much gas flow is occurring and the computer makes adjustments to the flow or to the EGR valve as needed.
Yes it is an EGR sensor. No it is not an EGR valve position sensor as in older systems. Hopefully that helps???
>>>>>>>>>>Action
Old Jun 6, 2016 | 10:01 PM
Fernie_Wan_Kenobi
So yeah dpfe isnt there. I saw this other thing that kind of looks like it though .
Is that it?
Old Jun 9, 2016 | 05:44 PM
alloro's Avatar
alloro
Alrighty ! So my grandfather has a scanner that he gave me. To check the misfire in the coil packs, I'm going to assume I connect it when the car is running right? Will it give me the code right on the screen?
For live data the engine needs to be running and for misfire reading go take a drive with the scanner connected and running in the live data mode.
majestek12
Mar 21, 2022 06:43 AM
jrtaylor
1997 - 2003 F150
29
Dec 16, 2006 03:52 PM
polar88
Dec 12, 2004 11:44 PM
reitman
Apr 11, 2002 03:29 AM
