I am hoping someone on the forum has or has access to the same configuration vehicle (stock version), and can share the information necessary to put the truck back to stock height.
I have a 2003 F350 4wd 6.0l Crew Cab 172" wb single rear wheel King Ranch. The build sheet lists standard front suspension and heavy duty rear suspension. The b-pillar sticker is devoid of any printing (it is there, just wiped clean).
My questions are:
1) What are the spring codes for the front and rear leaf springs?
2) How many leafs in the rear springs, not counting the helper?
3) I assume the front leaf springs have 2 leafs, correct?
