Missouri Chapter Join Chapter , Leader:77&79F250
Juneo what month it is? First day of summer is coming.
Old 06-27-2016, 07:59 AM
earthquake68's Avatar
earthquake68
earthquake68 is offline
RC. The front tires are dry rotted so bad, the tread is separating all the way around the outside. He won't get 5 miles before they explode. I had a couple used tires to throw on it for him.
  #272
Old 06-27-2016, 08:11 AM
John T super cab's Avatar
John T super cab
John T super cab is offline
Morning , i woke up dreaming bout a two speed rear end with 410 and 300 for the highway . Guss thats a lot to put in a small axle housing . Looks like a great day to saw some logs .
Alan theirs some people well it went something like this . He drove in to my shop ask my to look , frame was rot behind right front wheel . Did not want to fix .I said unsafe to drive ,he said good to go .No unsafe to drive ,good to go . My wife stoped me ,pointed to invoice that he signed where she had written every thing out and he signed . I left office .
  #273
Old 06-27-2016, 08:14 AM
whiskey runner's Avatar
whiskey runner
whiskey runner is offline
jihn T are you talking about a columbia differential .. or a quick change
  #274
Old 06-27-2016, 12:30 PM
earthquake68
Afternoon all.
I got the tires mounted on the Ranchero, (the ole' two prybar method to mount them on the wheels) fluids are full, lights work. He's on his own from there. He should be here tonight to pick it up.
I got most of the metal work done to the bottom of RC's tailgate and filled one of the gas fill holes in High Roller so far. I'm just tinkering today to take it easy. I'm still not 100% and don't want to push it.
  #275
Old 06-27-2016, 02:46 PM
whiskey runner
sounds like a good plan alan.. just tinker with easy stuff, a little with this and then a little with that.. keeps ya from getting wore out or bored
i woke up to a flat tire on the S10.... went over jacked it up and found a small rock in the tire, plugged it and all looks good..then while i had the tools out, i went ahead and sprayed the other tire, it has been leaking down once every couple of weeks or so..took awhile but i finally found it, must of been a locust thorn it was so tiny.. now maybe it will stay aired up on all four wheels for awhile..
worked till i was almost finished with the flat-bump, then decided to come in to get out of the heat and rest with a cool drink.. i need to drag my worthless old bones back out there and get the steering wheel put back on then go for a test drive.......
  #276
Old 06-27-2016, 04:07 PM
John T super cab
Something like a big truck ,is that a columbia . Or a overdrive box that bolts on the back of the trans . I just don't want to loose my granny gear but the 410 are a bit low for the road . I wanted a locker and that was the smallest gears i could find . just pulled the radiator to soder two holes ,should have tested it before putting it back now well i got to fix a hole in the radiator .
  #277
Old 06-27-2016, 04:17 PM
John T super cab
ya sound busy dave...
jeff i guess maybe i can come up there and haul it for you about anytime..when would be good for you?
alan looks great.. i think of may of found some wheels that would look groovy on it man... it would look normal sitting next to earthquake then.. ha ha ha ha
these might get the gear where i need , but not on my truck eather .
  #278
Old 06-27-2016, 05:30 PM
earthquake68
An NV4500 manual trans has a creeper gear and an overdrive. ...just sayin'.
  #279
Old 06-27-2016, 08:15 PM
whiskey runner
a columbia differential are the ones used on ford banjo rear end's from the mid 30's to the late 40's.. they still make quick change differentials.. but you have to remove the plate to change the ratio you will need to dig kinda deep in your pockets to get one..
  #280
Old 06-27-2016, 08:45 PM
whiskey runner
ups just called.. the driver got lost, so i wont get my brush hog parts for another day.. then i will have to go to town at the hardware store to pick them up. this is getting bad the old ups drivers always managed to find my house... ........ i guess it dont make much of a difference i really did not want em anyway.. ha ha ha ha ha
  #281
Old 06-28-2016, 06:25 AM
whiskey runner
good morning missouri...
i went out to play with the wires again on my 67 into 72 turn signal switch..i am having a problem with it.. i guess the 67 4 way flasher is wired different than my 72 4way is.. i tried moving wires around but sitll wacky..it all works ok except when i turn the wheel to cancel the switch..the 4 way flashers come on.....
i got lucky and bought a 'new old stock' original ford dotz-13341-b switch on ebay for 32.50...that is cheaper than they were asking for one in the catalogs and they are probably made in china....... did i mention i hate chinese parts!!!!
i wanted to say how nice and cool it is out there this morning.. thought i was going to have to put long pants on..
  #282
Old 06-28-2016, 07:54 AM
97 Mountain Man's Avatar
97 Mountain Man
97 Mountain Man is offline
i dont kniow terry.. that having to mow is not all that it is cracked up to be.. i wish i could afford to just pave over my whole yard.....
Word
  #283
Old 06-28-2016, 11:13 AM
whiskey runner
well time for a short break.. i went back out armed with 2 wiring diagrams one for the 67 and one for the 72.. i did some re-wiring of the switch and now all is good.. i wish i didnt get so much in a hurry and order the new switch... i guess it will be good to have one in stock..now that i know you can use the 72 switch in the older trucks and vice versa ..
  #284
Old 06-28-2016, 11:56 AM
BORDERBUM's Avatar
BORDERBUM
BORDERBUM is offline
Morning all! Bought my son his first car this past weekend and started modifications to his liking.
Here it is after we painted the brake calipers, and plastidiped the wheels. Changed the headlight bulb, cam position sensor , and passenger side window motor. Infinity G35. 03 model. Needs ODs and ends, but ready to pass inspection now.
  #285
Old 06-28-2016, 12:21 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,328 Likes on 2,477 Posts
Drink water folks, its hot hot out there.
Quick Reply: Juneo what month it is? First day of summer is coming.
