P 0308 Fault cylinder H misfire detected cylinder 8
New to diesel trucks and wondered if this recurring code is a serious problem. I clear DTC and truck will run fine. Might stay off for 2 days or 2 months and same code comes back. Truck seems to run just fine even with service light on.
Do you have any way to perform a Buzz and Cylinder Contribution Test? If not, search for Torque Pro and Auto Enginuity on these forums. A good engine scanner and the ability to save logs of different sensors is almost a must with these trucks IMO.
What year is your truck? How many Miles etc?
could also click the Torque pro FAQ link in sig also
