Transmission mounts
Old May 30, 2016 | 07:18 AM
obscurity's Avatar
obscurity
Transmission mounts
So I have my transmission (4 speed) out of my F3 because of a ring gear issue I mentioned in a previous post. I have been killing time cleaning everything up and I noticed that there is some evidence of a rubber mount where the transmission lands on the crossmember. I have been looking around but I have not been able to find anything on the usual sites (Macs, Lmc) is this part available?
I seem to find the speed parts everywhere but not many 4 speed. Not sure what to do if I decide to rebuild it.
Old May 30, 2016 | 10:52 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Van Pelts' seems to have it, see below
Old May 30, 2016 | 11:44 AM
obscurity's Avatar
obscurity
Wow that's it? Mine had a tiny amount of rubber around the threads but nothing like that. I assumed those were for the big trucks (f6, f7, etc) Thanks for the help!
Old May 30, 2016 | 01:04 PM
oldmerc's Avatar
oldmerc
oldmerc
Yep that's the one
Old May 30, 2016 | 01:12 PM
obscurity's Avatar
obscurity
It is also a spendy part. Seems like a rock hard piece of rubber would work just as well. I assume it is a fairly hard piece of rubber? Anyone know how thick?
Old May 30, 2016 | 06:50 PM
Marauder2004's Avatar
Marauder2004
That's an interesting item. I am at the same point and was wondering if there was a mount available but I never would have thought it looked quite like that or cost that much. I guess mine was long gone a long time ago, because it only had a trace amount of rubber around the bolts too.
Old May 30, 2016 | 09:02 PM
Brian~50F3's Avatar
Brian~50F3
Your only seeing the very top of the rubber, the rest is basically pressed in the cross member and held in by a plate. Here's the side view under the truck:
Here's the small portion sticking out
Keep an eye on eBay, one pops up every so often for 10-20 bucks.
Old May 31, 2016 | 04:28 AM
Marauder2004
That image helps a lot, thanks for sharing.
Old May 31, 2016 | 08:50 AM
obscurity's Avatar
obscurity
I'll have to look more closely at how mine works. From the photo it looks like you are buying a lot of rubber but only getting a small amount of bearing area advantage
Old May 31, 2016 | 09:01 AM
ALBUQ F-1's Avatar
ALBUQ F-1
If these are made of the same rubber as the F1 mounts, it's not much different than mounting to steel. The compounds are so stiff you can't press a fingernail into them. I have long wondered if any attempt to match OEM durometers is made, or if it's just some random compound. But you need something there.
FJones8668
May 2, 2022 04:05 AM
jerry_s
Mar 14, 2015 11:24 PM
Muppy1840
Feb 22, 2015 12:45 AM
77FordDW
Jun 6, 2011 09:55 PM
daddyjustang
Aug 2, 2010 11:11 PM
