1992 F150 4.9 6 Cyl
Old 05-29-2016, 02:36 PM
alburrito's Avatar
alburrito
alburrito is offline
1992 F150 4.9 6 Cyl
Recently bought this truck for work purposes. Ive noticed check enigine light comes on when accelerated hard such as merging on to freeway or going up hill but will come off by itself after few minutes. Any ideas/suggestions as to what might be the culprit?
Old 05-29-2016, 03:01 PM
xTHANATOPSISx's Avatar
xTHANATOPSISx
xTHANATOPSISx is offline
Check the codes stored by the ECM first. Even without the CEL being on, you can have codes that could help find the problem.
bigredtruck's Avatar
bigredtruck
bigredtruck is offline
My first guesses would be O2 sensor out of range or EGR flow out of range, but it could be any number of things. First step is pull the codes and get a direction from there.
You can read up on how to read codes manually through your check engine light, or you can get one of these:
Amazon.com: INNOVA 3145 Ford Digital Code Reader: Automotive Amazon.com: INNOVA 3145 Ford Digital Code Reader: Automotive
The code will be stored in the computer even if the light is off.
Old 05-29-2016, 03:18 PM
4DB's Avatar
4DB
4DB is offline
Get the ability to read codes (just too easy), but on a carb'ed motor the classic fault causing problems under heavy load is a partially clogged fuel filter causing fuel pressure at the engine to drop. When the load goes away, proper fuel pressure returns and the light goes out.
Old 05-30-2016, 12:19 AM
thehead406's Avatar
thehead406
thehead406 is offline
From what I've been reading on this site, the CEL only comes on for emission related problems. As stated above, pull codes, that will point in the right direction.
1991F250OH
05-05-2018 07:47 PM
mrsvegan
10-11-2013 08:10 PM
BearFootCustom
10-20-2010 10:44 AM
Spennyman
Bronco II
05-11-2006 01:12 PM
manasota
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
02-13-2005 08:47 AM
Quick Reply: 1992 F150 4.9 6 Cyl
