Help!
Old May 26, 2016 | 06:23 PM
Tmurph223's Avatar
Tmurph223
Help!
Hey everyone, I don't know exactly how to explain what is going on with my motor (352 fe block) here so bare with me here...
I am having troubles with over heating and an extreme amount of pressure in the radiator. The radiator hoses will swell up like a ballon when idling for a short amount of time and coolant will leak from the block, however I am not having the white smoke or frothy oil like I would with a blown head gasket. Also the temp gauge won't be reading anything, and after its ran the radiator will be completely low. The truck will then back fire a lot through the carb and then blow smoke out of the oil fill. I feel like I'm at my wits end with this! The head gaskets are new and the heads tourqed down to specs, all new intake manifold and gaskets as well with a new carb. Any ideas? Thank you
Old May 26, 2016 | 08:38 PM
DBSGarage's Avatar
DBSGarage
Have you looked at the thermostat? Possibly the water pump. You could have a blockage in the block somewhere that would cause that possibly.
Old May 26, 2016 | 09:04 PM
64highboy's Avatar
64highboy
Did you have the heads resurfaced. I had a truck with a warped head and it had problems with the rad hoses swelling. I don't think I had coolant in The oil.
Old May 27, 2016 | 12:11 AM
IICAP's Avatar
IICAP
It sounds like you have an air pocket in the block and everything is not filling up with coolant. A new T-stat is A MUST. When filling the system have the heater hose from the intake manifold or T-stat housing (not hose to water pump) disconnected and fill till coolant is at that level, reinstall the hose and continue filling rad. Leave rad down 1.5 " from the filler neck. Leave the rad cap Off, start it up and let idle to warm up. As it warms the coolant will rise in the rad. If all is well the T-stat will open and the rad level will drop as the heater and all, fills and pushes the air out.
Temp gauge probably didn't work because coolant did not touch it. If you had the cap on, Steam is what probably ballooned the hoses.
Now I don't mean this to be funny or insulting. I think your head gaskets had top or bottom and a front and rear to them. Where you aware and are they installed correctly? The water pump pushes the coolant thru the block to the rear and up into the heads. Then the coolant comes forward thru the heads to the T-stat area and to the rad. Just a thought if !st paragraph doesn't work for you.
Old May 27, 2016 | 05:46 AM
Tmurph223's Avatar
Tmurph223
Thanks guys! No offense taken on the head gaskets, I checked and re-checked when putting them on because the last thing I wanted to do was to take it all back apart again. Lol
however I currently do not have a thermostate in the neck there, it's just all open. The one I had was all gummed up from before and looking online I saw I could run it without one. With the rad initially full and the cap off, just turning it over it pumped a ton of antifreeze out of the top of the radiator so I'm assuming that might mean the pump is working? And the heads have not been resurfaced. I will take the pump off to see if there is any blockage in there though.
Old May 27, 2016 | 10:10 AM
IICAP's Avatar
IICAP
"With the rad initially full and the cap off, just turning it over it pumped a ton of antifreeze out of the top of the radiator" ????
Just cranking it over should not do what your describing, UNLESS you have blockage in the rad. SUGGEST, disconnect fan belt, rad full to top, crank engine over and see if you still blow coolant out rad top. If it is still blowing out, there is compression getting into the cooling system. See what this test does.
Old May 27, 2016 | 12:53 PM
Tmurph223's Avatar
Tmurph223
What would that mean if there is compression in the cooling system?
Old May 27, 2016 | 05:28 PM
IICAP's Avatar
IICAP
Compression from the cylinders, A leaking head gasket. DID YOU DO the test of removing the fan belt to stop the water pump from turning as I described??? It's a process of elimination to get to the cause of your problem, looking for the simplest things first
Old May 28, 2016 | 06:28 PM
Tmurph223's Avatar
Tmurph223
Yes, I did the test and yes water still pumps out of the radiator. As well as the smell and smoke of exhaust
Old May 28, 2016 | 07:15 PM
IICAP's Avatar
IICAP
Next step I suppose is to take out all the spark plugs. Now if you or a helper would look at the engine as the other cranked it over, you would look for coolant blowing out a spark plug hole. to determine which side or cyl(s) are leaking.
Preferably if you had or could borrow a cooling system pressure tester (to expensive to buy), and pumped a couple pounds pressure to the system, it would force the coolant to the leak area, then crank engine again to see what plug hole it comes out.
Guessing a head gasket not installed properly, head and block surfaces not cleaned properly, possibly a serious crack (hope not).
The ball is back in your court.
Old May 28, 2016 | 08:59 PM
john jamieson's Avatar
john jamieson
What about doing a compression test and look for leak down?
Old May 28, 2016 | 09:41 PM
IICAP's Avatar
IICAP
j j, I guess compression test will show weaker cyl(s). It is a choice and worth a try.
Tmurph, long, long time since I had a FE apart. On each side of the block were there 2 dowels that aligned gasket and head to the block? I forgot to add, look at the spark plugs for signs of water on them
Old May 29, 2016 | 07:21 AM
Tmurph223's Avatar
Tmurph223
Yeah there are the 2 dowels there that the gasket and head sit on. I can see that there is water leaking from the passenger side of the block as well, looks like the front but if I was getting water into the cylinders wouldn't it blow white smoke from the exhaust?
Old May 29, 2016 | 10:13 AM
IICAP's Avatar
IICAP
OK so you know something is going on with the passenger side. Can you determine/see the drip leak is where the head meets the block. Use mirror and light if needed.
Also you said " I can see that there is water leaking from the passenger side of the block AS WELL ". So did you pull the spark plugs and crank engine, look for coolant out plug holes?
Compression in a cylinder could be 140-160 PSI. On the coolant side there is no pressure and the coolant may not drip easily into a cyl. That is the reason I mentioned a coolant system pressure tester would be best as you could pump up to 15 PSI against the coolant and possibly push the coolant into a cyl(s) and cranking would spray that coolant out the plug hole.
Many parts stores offer tools for loan ( leaving a deposit ) you may have one in your area that offers a coolant system tester.
Old May 29, 2016 | 11:54 AM
KO1960's Avatar
KO1960
I would check your thermostat to make sure it's opening at the right temp. If there isn't a bleed hole, you can drill an 1/8" hole which will help with the overpressure and before the thermostat opens.
