I got to thinking about another tip on your custom bed...I used a length of 2x4x0.120 wall rectangular tubing instead of that flimsy sheetmetal sill. This really stiffens up the bed. I rounded the lower corners of the stake pockets and used a modified Pros Pick hiding hinge setup. Here is a pic of the work in progress, the pic in my previous post shows it ready for paint.
That's a good idea. I really like the way the rounded corners loom.
I got started on the bed tonight. I only got a few hours of work in but I made good progress. I started off by making the front frame work. I cut 3 pieces of 1x1 49" long. And 2 pieces 15 1/2 inches long. Then I squared everything up and welded the front frame together.
Then I clamped the frame to my sides and used the 3rd 49" piece of 1x1 to go across the rear of the bed. Next was cutting 2 pieces of 1x1 77" long to run down the middle of the frame work. I also cut some 1x2 and angel cut the ends to go on top of my header panel. Next was to cut some cross braces and side braces. Before I finish up the bottom frame work I need to mount my rear tires and see if I need to tub the bed or see if I can leave the bed sides smooth.
Pretty easy for the bed roll. On my 9' box I stitch welded the pipe on the bent up sides. Grind the welds smooth, body caulk in the seams, skim coat & paint.
Regards, Mark.
So no need to cut the tube to butt joint it to the bed side? I was going to but if I don't have to would save a ton of work.
I did mine the same way Badmoonreizn did. I did weld mine solid all the way along the seam. You position the tube so the curve is at the top of the bed side and the edge of the sheet metal side is down the curve slightly. The easiest way to get it right is to use a straight edge on the top of the lip on the sheet metal and top of tube. After I dressed the weld down I didn’t need any filler just primmer sand and paint. I also built my tailgate, latches and hinges.
