Stalls when put in drive....
New (points style) distr, MSD ignition, cam, intake, rebuilt 1405 edel. carb.
The problem I am having is the truck will idle great, rev pretty good just sitting still. As soon as I put it in gear it sputters and pops and just wont move more than a foot in either direction without stalling. If I rev it up and drop it into gear I get the same thing.
I have sprayed the intake area with carb cleaner.... sprayed around vacuum lines and base of carb and no indication of a leak. I've rotated the distr looking for a slightly better timing but same result. No timing light or vacuum gauge.
I'm not the greatest mechanic, so I am stumped at this point. I didn't install the cam, intake, distr..... a friend did that, but it idles great so I think the timing must be within the adjustment zone.... It would not run if he installed it wrong right?
what am I missing??? The trani functioned fine before the upgrades and this doesn't really feel like its a tran issue....
The only other clue I have is that the carb adjustment screws don't make much of a change at idle.... all the way in or out it still idles okay. I did the rebuild so I'm sure it was done correctly.
Thanks in advance
You do have a timing light, right?
