CB radio installation
Old Aug 15, 2003 | 06:50 PM
stepside64's Avatar
stepside64
I have a CB radio I would like to install in my 1986 Ranger. The black wire goes to the ground and the red wire is ignition switch or battery or something like that. I am not quite sure where to connect the red wire to on this 86 ranger. This ranger is a bit moe confusing than the classics that I ususally work on.
Travis
64 f-100 stepside
65 f-100 styleside
86 ranger
Old Aug 15, 2003 | 07:38 PM
Ken00's Avatar
Ken00
Either find a circuit at the fuse box that is hot in run or tap into the radio wire. Make sure you get on the protected side of the fuse.
Old Aug 15, 2003 | 07:49 PM
PSKSAM2's Avatar
PSKSAM2
I am an amateur radio operator. When I do a mobile installation, I usually run power direct through a fuse back to the battery. It helps to eliminate a little noise (definitely a plus on AM or SSB) and provides a solid power source (helps a lot when you push 25W or more). For a CB you can tap like Ken said where you can find a hot, since you aren't pushing much power. There is a place called FireStik that has some cool antenna mounts. They have one that fits into the stake hole in your bed rail. I may get one when I put in my HF installation in the truck, but it'll work well with any 3/8 in CB whip. It can be found under "Mounts and Accesories, P/U Stake-Hole".
http://www.firestik.com/
