Missing check valve?
Old May 25, 2016 | 07:02 AM
jeffreyclay's Avatar
jeffreyclay
I drive a '94 E-150 conversion and noticed the usual symptom of the dashboard air flow diverting from dash to defrost when pulling a hill, long period acceleration, etc. I was testing to isolate a vacuum leak and noticed that I couldn't find a check valve anywhere on the supply line to the reservoir tank. The source line came from a shared block on the intake manifold directly to the tank.Everything looks factory stock, no monkey repairs. I picked up a Doorman generic valve but it passed air from either end so I didn't use it. My question is, did Ford ever release a version without the valve? Doesn't make sense to have a reservoir without one or have they incorporated it into a fitting that doesn't look like a short stack of quarters with nipples on both sides?
Old May 25, 2016 | 07:37 AM
jimandnena's Avatar
jimandnena
Hi Jeffery,
the short answer is no, it doesn't make sense to me for any reservoir to not have a check valve back to the source. There is a huge thread on the vacuum problem you describe, all involve a check valve somewhere. jim
Old May 25, 2016 | 09:30 AM
JWA's Avatar
JWA
I believe the check valve is internal to the reservoir, the intake port runs directly to that valve via the reservoir fitting.
If the Dorman part was defective it should be returnable. Not much money I know but still aggravating to have a new part not work regardless.
Link to the lengthy but informative thread Jim mentions: https://www.ford-trucks.com/forums/1...efrosters.html
Old May 25, 2016 | 12:00 PM
jeffreyclay
Very interesting about the factory incorporating the valve within the reservoir. I tested the reservoir for leak, it passed. I suppose no harm in adding an external check valve. Thanks for the input. Jeff
Old May 26, 2016 | 05:52 AM
JWA's Avatar
JWA
No harm at all adding a check valve----hopefully that solves this issue.
snorindad
Dec 31, 2020 09:03 AM
xtal_01
May 21, 2016 03:21 PM
alpo23
1978 - 1996 Big Bronco
May 5, 2003 09:17 PM
