Fried ECU
Old 05-24-2016, 09:53 PM
RandR10's Avatar
RandR10
RandR10 is offline
Fried ECU
Hi guys. I just fried my ECU. Truck was running fine. Was backing up to log splitter and got out to check alignment, truck shut off when I was walking back up to cab. No sputter or anything, just like I shut the key off. When I got in I could smell something burnt. After troubleshooting, found that no ground was going to the fuel pump relay, so I pulled the ECU because the ECU provides that ground and kicks it off for pump priming when you don't start it right away. Sure enough, that was the thing that let the smoke out. Opened it up and found a burned capacitor inside.
Question for the forum: Is this something that could happen spontaneously/internally to the ECU, or do I have a short somewhere in the harness?
It's strange to me that if it does have a short, it would happen while the truck was sitting still and idling, which means no wires moving around. I don't want to install another ECU and fry that one too.
88 F150 4.9L 5-speed
The green capacitor in the bottom of the frame is the culprit. One of its legs melted off and it burned right through the other side.
Old 05-24-2016, 10:13 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
The capacitor probably shorted internally, and then quickly died.
Pins 1, 37 and 57 should get battery power with the key on.
Old 05-24-2016, 10:18 PM
RandR10's Avatar
RandR10
RandR10 is offline
Oh awesome. That's what I was hoping for. I'll post how it goes tomorrow. Hopefully I don't flush $130 down the drain in about 3 seconds tomorrow when the new ECU comes in
Old 05-25-2016, 10:19 PM
RandR10's Avatar
RandR10
RandR10 is offline
Installed the new ECU today and it runs like a champ. Took care of the rough idle and hesitation I could never figure out too. Must have been on the verge for some time now. Regardless, very happy that it's fixed.
mattjohnston24
04-10-2019 07:38 PM
rwdfan
08-14-2011 01:07 PM
stroken
13
10-07-2010 08:33 PM
RST1000
1997 - 2003 F150
13
02-05-2008 03:16 PM
cobrar97
08-29-2007 05:45 AM
Quick Reply: Fried ECU
