Running rough @ highway speed
Old Aug 15, 2003 | 05:57 PM
Tim Halliday's Avatar
Tim Halliday
1987 Ranger 2.9L 2wd 283,000km (175,000mi)
When I drive at speeds of 90kph (55mph) or more, my truck will begin to run rough, loose speed and blow black smoke from the exaust for periods of 10-30 seconds at a time.
This first happened to me while driving home from Ottawa (7hrs away) after having to change my transmission.
I read the codes and got:
33 - EGR Valve fault / not closing properly
and
29 - Insufficient input from the Vehicle Speed Sensor
Any help/advice would be greatly appreciated!
Old Aug 15, 2003 | 11:47 PM
Beast12's Avatar
Beast12
But seriously though, hope to get this to the top of the page for ya! Good luck!
-Matt
Old Aug 16, 2003 | 07:19 PM
Ken00's Avatar
Ken00
Have you run the pinpoint tests for the codes? If you don't have them I could scan them from my 1988 Ford manual and email them to you. Also make sure the fuel pressure regulator isn't leaking.
Old Aug 18, 2003 | 09:32 PM
Tim Halliday
Update:
I found the vehicle speed sensor disconnected, so I plugged the harness back in. This has not solved my problem.
I did the Key-On-Engine-Running test tonight and got a new code in addition to #33:
41 - HEGO (H20S) sensor voltage low / system lean
Is that the oxygen sensor? It may have been banged around when the transmission was being changed out, and it got wet too. The y-pipe that holds the sensor was full of water when we went to put it back on, because it rained a lot while I was in Ottawa.
How do I do this?
Old Aug 19, 2003 | 09:00 AM
Ken00's Avatar
Ken00
Check the wiring, it is very common for it to get burned or pinched between the tranny & block. Yes its the oxygen sensor.
Pinpoint tests are used to determine the exact cause of a code, if you need it let me know.
Old Aug 20, 2003 | 05:09 PM
Tim Halliday
We replaced the oxygen sensor and the code is gone now. I'm still having the problem though. In fact, it is a lot worse now. The truck has got an appointment at our local dealer tomorrow. Hopefully it won't cost me too much!
Old Aug 20, 2003 | 05:20 PM
Beast12's Avatar
Beast12
Talking Running rough @ highway speed
It's 6:15 and you are home from work already?!?! And you have an appointment tomorrow? That means you are taking the day off?!?! I would highly suspect your main supervisor is gone from work and you are slacking it up!! Anyways, good luck on your truck and hopefully it doesn't cost too much! There's no place like to "stealership" to spend your paycheck!!
-Matt
Old Aug 22, 2003 | 03:41 PM
Tim Halliday
Well I don't know any more!
I've replaced the O2 Sensor, fixed the speed sensor, cleaned the IAC, replaced the MAP sensor and had the coolant temp sensor replaced. The dealer even checked the fuel pressure regulator for me and said it's fine and there is nothing wrong with the fuel pressure. Each time I do something, the truck runs fine long enough for me to think it's finally fixed, and then oh, look! it's doing it again.
The only code left is the one about the EGR valve. It has not been connected to the manifold since I got the truck, so I don't think that it would have just started causing trouble now.
- Tim
Old Aug 22, 2003 | 06:49 PM
Ken00's Avatar
Ken00
Have you check the FPR for leaks, also check the exhaust system for leaks.
Old Aug 22, 2003 | 07:06 PM
Beast12's Avatar
Beast12
This guy with the problems is my friend so I know what he is gonna ask. He is gonna say "What the heck is a FPR??" LOL! Seriously! I don't know even know so can you tell me what it is. I know he just got all brand new exhaust from (and including) his catalytic convertor back so that couldn't be his problem unless when they replaced the tranny they didn't put it back on properly! MMmmmm? Thanks Ken!
-Matt
Old Aug 22, 2003 | 07:10 PM
Ken00's Avatar
Ken00
Fuel pressure regulator.
You need to pull the vacuum line off and see if there is gas in it.
An exhaust leak from the heads back can cause a false lean reading from the O2.
I'm still worried about the O2 wires since the tranny was just done.
Old Aug 29, 2003 | 08:21 PM
Tim Halliday
While I was at work, I had my dad look at everything that you had mentioned. He found nothing wrong.
No gas in the vacuum line on the FPR.
No exaust leaks
and the wires to the O2 sensor looked fine, no visible damage due to pinching, burning, etc.
To top it all off, the truck has been running great for the past 2 days now! It was causing trouble one night after I filled up with gas, the next day it ran fine. When I fill it up again, I will see if it is still using too much gas, but until then everything seems to be working fine. Hopefully it will stay that way.
Beast12: This supports our theory of Fords fixing themselves!
- Tim
Old Aug 29, 2003 | 08:53 PM
Beast12's Avatar
Beast12
I know! I have been saying that for a long time! That's what FORD stands for: Fix Or Repair Demselves!! Good luck on your truck man!
-Matt
Old Sep 4, 2003 | 08:57 PM
Tim Halliday
Well, it's been almost a week since I had any problems. I still have no idea what caused my trouble, but everything seems to be back to normal.
I did have a fuel filter that was rusted out so bad that it started leaking through a rust hole, but that's the only trouble I've had since my last post.
- Tim
