Australia Chapter Join Chapter , Leader: ChunderDownUnder
Recomended Sydney mechanic
Old 05-30-2016, 05:53 AM
1973_240z's Avatar
1973_240z
1973_240z is offline
Originally Posted by ChunderDownUnder
if u can try and support someone who supports us.
You wont find better people to deal with.
Ford - 99-03 Super Duty 7.3L - HPOP & Related - Riffraff Diesel Performance
And another site I couldnt live with out
1999-2003 Ford 7.3L
there combo kit is a must for all, the instructions are detailed for all types of repairs as well
Cheers mate, I have ordered the basic oring kit from diesel orings also the quick release connect tool. I hope that the oil leak is caused by the high pressure hoses only. On the last drive I couldn't see any more evidence of the fuel leak. One repair at a time.
Old 05-30-2016, 05:57 AM
1973_240z's Avatar
1973_240z
Originally Posted by Aussie BrianB
Mike,
The fuel issue is a bit of a mystery.
The two hard lines from the bowl to the fuel rails on my engine were looking a bit worse for wear and I replaced
them with steel braided teflon lines and "Proflow" AN style fittings.
Check you lines and see if they have any hairline cracks.
Just a stab in the dark I admit and there are other more knowledgeable members that may be able to solve it.
As for the HP oil lines leaking the answer is yes, they can leak that much oil, it is under a very high pressure.
I advise you to get a new set of lines.
These are what I used on my engine.
CNC FABRICATION 7.3L E99-03 COMPLETE REPLACEMENT HPOP AND HPX LINE KIT - 99-03-ENGINE - POWERSTROKE 99-03 - Products
They are an excellent product and are well worth the cost.
If you read post six in this thread
https://www.ford-trucks.com/forums/1...3-removal.html
you will find a list of many links to info and products that you may
find helpful.
Best of luck.
Thanks mate, the fuel lines seem ok and the leak can't be to substantial as it runs fine. At this point re the HP lines I think I'll just replace the seals as I imagine they have gone due to age not kms and if I get another 10 years from them that's cool.
Old 05-31-2016, 02:14 AM
ChunderDownUnder's Avatar
ChunderDownUnder
ChunderDownUnder is offline
u r in Sydney right. If so check with me before u buy any special tools. I most probably have it
Old 05-31-2016, 03:40 AM
1973_240z's Avatar
1973_240z
Awesome, will do mate.
Old 06-04-2016, 06:07 AM
1973_240z's Avatar
1973_240z
Guys, I need advise. I have replaced the two discharge fittings with new o rings. However I could not get the springs to stay inside the fitting when threading it in. I am concerned that if the spring did not find the hollow of the fitting then it will currently be compressed. What are your thoughts, would hate to start engine and cause damage.
Old 06-04-2016, 07:07 AM
Aussie BrianB's Avatar
Aussie BrianB
Aussie BrianB is offline
Mike,
The best advice I can offer is read these two documents,
http://www.dieselorings.com/docs/8-02xfittings.pdf
http://www.dieselorings.com/docs/fullHPOP.pdf
if you have not already done so.
I have completely rid myself of the quick release fittings
so I have no hands on experiecne with servicing them.
Hopefully some other FTE members can be more helpful.
Old 06-09-2016, 05:24 AM
1973_240z's Avatar
1973_240z
Thanks for the input Brian, I had gone through those guides.
I was hopeful the spring was seated ok and started it. All good now no oil leak. However I have since learnt that buying the orings from the states is not the best method. You can get the end plugs completely assembled for $56 each in Australia from F series diesel spares Brian 0425 818 171
9748 1229.
The fuel leak was a hairline crack in the fuel filter cap.
Thanks everyone for your help.
Cheers. Mike
Mowing Man
19
05-15-2013 09:52 PM
KC Ray
04-19-2013 09:56 AM
joeyroe
06-06-2008 09:50 AM
new ford fan
01-26-2007 10:14 PM
1 Cajun
11-19-2006 08:22 PM
Quick Reply: Recomended Sydney mechanic
