Idle Set Screw
Old Aug 15, 2003 | 03:16 PM
1yamman350's Avatar
1yamman350
Idle Set Screw
my 94 ranger idles terribly but runs fine with any gas. i was wondering if i could not just turn that set screw on the linkage so that it always has a little gas? it says something about not to because it is computer controlled. could i unhook the iac and just use that screw to set my idle? seems like it would work to me but i dont know alot about these electronics. thanks
Old Aug 15, 2003 | 07:33 PM
Ken00's Avatar
Ken00
Idle Set Screw
Don't mess with it unless you know what your doing, clean/replace the IAC and look for codes.
Old Aug 16, 2003 | 01:26 PM
1yamman350's Avatar
1yamman350
Idle Set Screw
so you dont think it would work to manually set the idle speed? also everyone talks about pulling codes? do i need a scanner or something to do this with? thanks
Old Aug 16, 2003 | 09:57 PM
Ken00's Avatar
Ken00
Idle Set Screw
It would work but you wouldn't be fixing the problem. Check out the link in the tech info post for pulling the codes.
