Parking Brake
Old May 21, 2016 | 08:40 AM
homertwo's Avatar
homertwo
Parking Brake
I have a 2001 F250. The parking brakes are gone. I mean there is no liner left on the shoe.
I would need to replace all the cables and brake hardware, and shoes.
Do they work good enough to justify the expense of replacing all the parts.
Seems like everybody I know that has a Ford, don't use the parking brake anyway.
What do you think?
Thanks
Old May 21, 2016 | 09:10 AM
jetjockey99's Avatar
jetjockey99
I would fix it. It is not a hard job, but will take some time. Make sure you check the backing plate closely as they like to rust out causing problems with the parking brake. In some states if you get caught with a non functioning E-brake you will get a ticket. I don't have that problem but having a functional parking brake comes in handy when doing some repairs.
Old May 21, 2016 | 09:35 AM
homertwo's Avatar
homertwo
The backing plate will need to be replaced too.
Old May 21, 2016 | 05:36 PM
Chuck's First Ford's Avatar
Chuck's First Ford
check your local laws.
but for me.. on my Dodge (Ram) 2005 .. they rusted up right after 1 year old (2006).. Warranty would not cover the repairs... I drove it for another 9 years that way.. Oh.. the Dodge had a manual transmission.
that is just how Good the 7 year , 70,000 warranty was.
Old May 22, 2016 | 09:50 PM
wrvond's Avatar
wrvond
If my ignition is off, the parking brake is engaged. In fact, I put it in neutral first, set the brake, then into park.
Old May 27, 2016 | 11:01 AM
Freightrain's Avatar
Freightrain
Parking brakes work fine when they are adjusted and in good working order. My 2000 F350 would hold my 14K trailer on a grade with only parking brake on(6spd).
Typically no one uses them and the cables rust solid and make them useless.
ajstephan
Mar 13, 2018 08:16 AM
Mikeman
Jul 13, 2014 10:36 PM
aaroncrew
Dec 2, 2013 01:07 AM
Dans2Fords
Feb 27, 2012 11:08 AM
TexasA&M
Jun 24, 2011 09:31 AM
