Bronco II Ford Bronco II
air conditioner problem
Old Aug 15, 2003 | 02:02 PM
grafter's Avatar
grafter
I have an 89 Bll. when i have the ac on max it blows cold but it doesn't seem to blow at a high speed. If i remember, there should be a noticeable difference between the regular ac performance and when it is pulled all the way to the left to max air. Please help a fireman. thanks
Old Aug 15, 2003 | 07:41 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
The difference is the air is recirculated on max.
Old Aug 16, 2003 | 11:29 AM
grafter's Avatar
grafter
i realize that the ac recirculates when on max air. the problem is there is no difference when i switch from panel to max air. thanks.
Old Aug 16, 2003 | 04:55 PM
WeWonIt's Avatar
WeWonIt
Ken00 is correct as usual, the "Max" only tells the system to recirculate the already cool air inside the vehicle. Your fan switch tells it to blow more air or less, maybe that is your problem.
Old Aug 16, 2003 | 07:16 PM
Ken00's Avatar
Ken00
If you don't get the recir. I would then check the door operation, I believe its vacuum operated.
Old Aug 18, 2003 | 05:23 PM
grafter's Avatar
grafter
Ken, thanks alot. i'll try that. gary
