Interchangable Fuel Floats??
Old Aug 15, 2003 | 01:44 PM
70RangerSister's Avatar
70RangerSister
Question Interchangable Fuel Floats??
I have a 1970 Ranger F100 and the fuel float is way past gone. No place here has any 70's in junk yards and the float has been discontinued by ford. I was wanting to know if the fuel float and arm is interchangable with anything else, new old, it doesn't matter to me. Thanks
Old Aug 15, 2003 | 03:16 PM
justinkramer072's Avatar
justinkramer072
If you want to replace the whole sending unit, most auto and boating stores will have them in stock. They're not very expensive either. I'm not sure if a new unit would work with a factory gage though. It depends on the electrical properties of both. Maybe someone else could help with that info.
Good luck.
Old Aug 15, 2003 | 11:19 PM
fordeverpower's Avatar
fordeverpower
I think that the arm will interchange as long as the gas tanks are similar sizes. I took the unit out of my 78 because the float had a hole in it. The parts are discountinued by ford as you said. I went to a old ford guy and he gave me a float. It was small and barrel shaped and was made of plastic. He also said that you can use SEAL ALL the fix any holes. THe **** works too. It resists gas and holds to the float. Also works on gas tanks.
