1978 - 1996 Big Bronco
Steering Seizes/Binds ..... Suggestions?
Old Aug 15, 2003 | 12:07 PM
ConstantFiddler's Avatar
ConstantFiddler
My Steering For my 92 Bronco seizes/binds and i am not sure why. I checked the power steering fluid and it seems to be ok. i think it might be the grease zerks but i am not sure, also i am not sure where all the grease points are located. respond ASAP with any suggestions. Thanks
Old Aug 15, 2003 | 01:15 PM
JBronco's Avatar
JBronco
It could be the steering box itself. Also check that the belt is not loose and the slipping on the ps pump.
Old Aug 15, 2003 | 02:44 PM
DW2455's Avatar
DW2455
yeah what he said, Check your belt tensioner and make shure your belt is not worn and stretched allowing slippage, that would make the steering jerky. DW
Old Aug 15, 2003 | 09:51 PM
93EddieB's Avatar
93EddieB
if you have a steering stabilizer make sure the rod is not bent
