Sponsored by: Real Truck
F550 thinks trailer is connected?
Old May 17, 2016 | 07:59 PM
IHpuller450's Avatar
IHpuller450
Alright,
Working on a 2016 f550 chassis cab with a dump bed on it tonight that when you turn the ignition on "trailer connected" displays...
If you run through the system check the screen comes up and tells you the gain for the TBC and underneath it says "no trailer" but once the system check is over it chimes from under the dash and "trailer connected" displays again.
I have already pulled the 7-way plug and inspected the wiring as far back as I can get to without having to drop the fuel tank. Nothing seems out of place or fishy... Also eliminated the bed wiring, they have it spliced into the 4 wires from the harness for marker (brown), ground (white) LH turn (yellow), and RH turn (green).
Anybody experience anything similar to this? The truck only has 135mi on it, so I wouldn't suspect that any of the factory connections have had time to grow corrosion, but then again it's hard to say how long it has been sitting waiting to get a bed...
Thanks in advance!
Old May 18, 2016 | 06:59 AM
Crispy71's Avatar
Crispy71
My first thought is it's a harness issue. I had an 04 F150 that had an incorrect harness installed at the factory. My other thought is maybe the people who installed the dump bed tapped into the wiring harness under the cab incorrectly.
Old May 18, 2016 | 07:46 AM
Spad30's Avatar
Spad30
Trailering
Originally Posted by IHpuller450
Alright,
Thanks in advance!
Just put it in reverse and it will go away. My 2016 F-350 does the same thing but as soon as I put it in gear it goes away.
Old Jul 12, 2016 | 05:43 PM
Rtortorello's Avatar
Rtortorello
Alright,
Thanks in advance!
Have you figured this out yet because my F350 is doing the same thing brought it to Ford they changed the module and this did not work
Albert Relation
May 18, 2019 07:58 PM
TheLex
Apr 18, 2018 07:34 PM
BillBraskey
WTB - Parts & other
Jun 9, 2017 11:55 AM
gvmiller
May 1, 2017 05:56 PM
984x4F150
1997 - 2003 F150
Sep 15, 2003 10:37 PM
