Sponsored by: Real Truck
1994 F250 starting problem
Old May 16, 2016 | 09:59 AM
Rangers999's Avatar
Rangers999
I have a 1994 F350 XLT with a starting problem. When I use it drive it for a while, shut it off for a short time then try to start it again and it won't start up, the starter just spins. I checked that both fuel pumps are running prior to starting truck. I have replaced the following items on the truck. The started module, the ignition coil, the entire distributor and all fuses related to starting. It does not matter if it is dry out or wet. I can start it again after the truck cools down. Does antone have any ideas? I was thinking on changing the wires and the plugs.
Thanks
Old May 16, 2016 | 10:26 AM
Squisher's Avatar
Squisher
Try holding it to the floor when it won't start and see if it fires up like a flooded vehicle. If so, I'd bet on injector leak down.
Old May 16, 2016 | 12:27 PM
droldsmorland's Avatar
droldsmorland
More info...Does it have the Dura-Spark ignition? I think it does. Is it a 460? If so could be the spark module is getting ready to go. Also be sure all grounds on the start AND ignition circuits are clean and tight. Heat causes increased resistance. With bad grounds it makes electrical components work even harder when hot. If the module or other electrical components are on the edge of going bad thats when it will show up. There are several places to find good trouble shooting procedures on the Dura-spark system. Its been 25 years plus since Ive worked on that system. I dont remember if the hall effect in the distributor needs to be replaced with the ignition box. I wouldn't even know where to look for my Ford Dura-Spark troubleshooting guide.
A quick google produced this... its a pretty good one
| Repair Guides | Duraspark Ignition Testing Charts | Duraspark Ignition Testing Charts | AutoZone.com
Look here at FTE too...Look at the last post on the first page. There is a PDF of Dura Spark II...
https://www.ford-trucks.com/forums/1...ble-shoot.html
Old May 16, 2016 | 12:37 PM
Rangers999's Avatar
Rangers999
Thanks you guys, I will try both suggestions and get back to you.
1961econolinePU
May 5, 2016 03:07 PM
bulldogcountry1
Oct 19, 2014 08:53 PM
1985.460
Feb 22, 2013 10:37 PM
marcomjl
Mar 28, 2010 10:30 AM
jdemoNC
13
Dec 31, 2006 12:30 PM
