First post. Code 172 has me lost.
Old May 13, 2016 | 08:41 AM
Lead Head's Avatar
Lead Head
Which two pins?
Old May 13, 2016 | 08:47 AM
frosty95's Avatar
frosty95
Originally Posted by Lead Head
Which two pins?
29 and 49 on the eec connector. O2 sense wires. I get that voltage at the o2 sensor as well. Pretty sure it was there with and without the sensor plugged in.
Old May 13, 2016 | 08:52 AM
Lead Head's Avatar
Lead Head
Something sounds a little off there. I'd disconnect the O2 sensor and the EEC connector, and check for continuity between the O2 sensor pin and Battery Positive.
Old May 13, 2016 | 09:21 AM
frosty95's Avatar
frosty95
I wish it was that easy. Little to no resistance down both wires from eec to the sensor plug. No connection to vehicle positive or ground. I dont remember if I actually bothered to change the ohm range while checking that though so I might have to check again. If there is a short to positive its in the several thousand ohm range or higher because I only had 1.3v without the sensor plugged in and not 12.
kbystrak
1997 - 2003 F150
Apr 26, 2014 09:12 PM
blue&white
1978 - 1996 Big Bronco
Aug 8, 2013 06:23 PM
octaneforce
Jan 17, 2012 08:08 AM
BSmitty
1983 - 2012 Ranger & B-Series
Aug 23, 2007 07:51 AM
12013134
1997 - 2003 F150
Jun 26, 2003 08:56 AM
