I have a 2002 F250 with the 7.3. My question is, I have a battery tender that is hooked up (pig tail plug in) on one battery. The fact of how the batteries are hook up to the charging system, does this mean that both batteries are being charged? Thanks in advance. HaroldMac
I find my tender does a better job when it's connected to the end battery and not the middle one (if that makes sense). It seems that it charges both better when connected like that. If connected to the middle battery, the end battery does not seem to maintain as well.
Ok thanks. I get confused on this, I also have a Deuce and it has 24 volt system. Just wanted to make sure i had this tender hooked up right.
If you have 2 12v batteries hooked up in series to make a 24v system, each battery needs to be charged separate. In parallel they both charge, but not series.
Or you use a 24v charger but this has nothing to do with a pickup
