If you have a two wheel drive the front is disk and the rear is drum. They are both press in studs.I have removed them by, after removing them from the truck, put them on a flat surface and hit the stud with a hammer. One or two hits should drive them out the back.To replace them tap them into the holes. Make sure you tork the studs, then check them after driving the truck 10-20 miles.
