Ford 9" disc conversion rotors...
Old Aug 14, 2003 | 07:25 PM
USpatriot's Avatar
USpatriot
I'm doing a disc conversion for a 31 spline 9" I pulled from a 85' Bronco. I've got the caddy calipers and caliper brackets, but I'm having trouble finding a rotor that'll work.
One person told me to get a CJ rotor, so I went to NAPA with the 9" shaft. Needless to say, the guy didn't tell me that I'd have to machine the shaft mounting plate down about 1/4" to fit the CJ and F150 front rotors.
Another guy tells me that a 81' trans-am rear rotor will work. I was somewhat skeptical that it would even have discs in the rear on that year. Well, the guys at NAPA looked and found no rear disc for an 81' or any year trans-am.
So, I decided to try having NAPA ship in a 79' Lincoln. It had the 9" with disc brakes, but it was a 28 spline shaft. Will the rotor for that be the right size without having to machine the mounting plate of the shaft down?
Does anyone know if there is an automobile company that manufactured a rotor that will fit the 31 spline shaft mounting plate of a 9" without having to drill or machine? Did GM, Ford, AMC, Chrysler or anyone make something?
I want something that I don't have to special order from a disc brake conversion kit. I don't want to have to call TSM and buy their rotor for some $200.
Old Aug 15, 2003 | 04:46 AM
Torque1st's Avatar
Torque1st
Posting Legend
Have you read thru the disk conversion tech articles here and performed a search?
Old Aug 15, 2003 | 10:05 AM
beartracks's Avatar
beartracks
i've had a couple of friends try to do conversions with factory parts only to find out it wasn't worth the time and expense. A kit from Stainless Steel Brakes or simular turned out to be a good deal.
Old Aug 15, 2003 | 10:45 AM
USpatriot's Avatar
USpatriot
Yes and Yes. I've also search the Pirates Of the Rubicon message boards, BC Broncos tech articles, some mustang tech articles, HP44 axle swap articles looking to see if disc conversions were done. My question wasn't answered by either.
I know the so-called "rules" with message boards, "if you haven't searched first, don't ask" and "if you don't find it in the first search, search again before you ask the question." I'm over at Pirates Of the Rubicon constantly looking for ideas, they're ruthless over there. They most deal with Jeeps and Cruisers though. I thought since this site was dedicated to FORD, that I'd find something, but I didn't, so I asked.
I don't post unless I can't find it on a message board or in a search engine. Being flammed once at POR teaches you pretty quickly.
Old Aug 15, 2003 | 12:40 PM
USpatriot's Avatar
USpatriot
Well, the lincoln versailles rotor came into NAPA this morning and I went to check it out. They are extremely too small, much smaller than the CJ and F150 rotors. So, I called TSM mfg. and asked them how much they would sell the rotors for. To my suprise, they are only $90 each, twice as much as a regular one, but I don't have to machine anything. I think it's worth it.
