help pls. 6.0 no start
Old May 6, 2016 | 01:41 PM
C.Haight's Avatar
C.Haight
First let me say thanks to this forum... it has helped me many, many times. I have never posted but have spent 100's of hours reading posts. I appreciate the ppl who give their time to upload PDFs, spreadsheets and help others. Its an amazing thing. Here is my situation. I have a early build 2003 f350 6.0. It will not start. Readings are good. ficm 48 to 48.5, synced, icp volts .30, icp climbs above 1200 psi, bat 13 to 13.5, ipr 14.8 to 40, fuel pressure 82 psi during crank..... will not start. It is driving me nuts. Any help would be greatly appreciated. Last week tore it down and replaced the tube of the hpop, found a leak in map hose and cleaned the turbo (vanes, ring). Ran ok for a week... shut it off and my sons baseball practice and will not start.... towed it back 2 days ago and nothing..... just cranks... any ideas would be greatly appreciated. Im at a loss. Another question would be where do i air test the hpo system on this truck.... ICP and IPR are in the back of the motor and hard to get to. I have read there is a way to do it under the valve covers.... not sure. Thanks Guys.
Old May 6, 2016 | 01:57 PM
senix's Avatar
senix
Welcome to FTE. Since this has to do more with the 6.0 I moved it to that area
Old May 6, 2016 | 02:00 PM
C.Haight's Avatar
C.Haight
More Info
MAP is @ 14.0
BAR is @ 14.0
Was hard to start all last week and was vibrating in low rpms while driving 40-50 mph. Checked FPW and it was at like 2000 i think... while cranking. Thanks agin.
Old May 6, 2016 | 03:57 PM
WatsonR's Avatar
WatsonR
You need to check crank/cam sync, should be a 1, FICM sync should be a 1.
What rpm are you turning while cranking?
WatsonR's Avatar
WatsonR
Old May 6, 2016 | 04:01 PM
WatsonR's Avatar
WatsonR
Your readings look good. If your getting FICM sync, that's good. Check the FICM relay, swap it with one of the others right next to it, they are the same.
Old May 6, 2016 | 04:33 PM
C.Haight's Avatar
C.Haight
Thanks for the response. Ficm sync is 1. Rpm 'so 350.... Highest. Ficm logic power is anywhere from 10.5 volts to 11.6.... Is that right? Will swap relay later today when I get home.... Thanks
Old May 6, 2016 | 09:34 PM
C.Haight's Avatar
C.Haight
Anyone else out there have any ideas? I live in Montana and a truck is a must..... Let me know.... Greatly appreciated
Old May 6, 2016 | 09:50 PM
WatsonR's Avatar
WatsonR
Sorry. Was flying home from Japan.
You need to check pulse width for the injectors, see if they are being commanded to give fuel.
Does the ICP voltage ever change? It needs to be above .8, more like 1.0v.
Tried unplugging the ICP, it has enough pressure, not enough voltage isn't good.
Old May 6, 2016 | 09:58 PM
C.Haight's Avatar
C.Haight
Hi Randy, yes the ice voltage raises when truck is turning over(trying to start)... I checked fpw fuel pulse width.... It was 2000 plus while cranking. Is the Ficm logic voltage to low? 10.5 to 11.5 volts. Could it be my batteries.... Engine seems to turn over fine.... Frustrating dam thing..... How was the flight.... That's a long one.... Thanks
C.Haight's Avatar
C.Haight
Icp not ice.... Dam auto spell
Old May 6, 2016 | 10:01 PM
Sal_Monella's Avatar
Sal_Monella
Not sure if this will help. I have an 03 F350 6.0
Last week it quit on the road and would not even crank.
Turned out the EBP sensor connector was crushed and shorted resulting in a "No Crank" and the fuel pump took a dump.
Suppose I'm just that lucky. Should have bought a lottery ticket.
Old May 6, 2016 | 10:05 PM
87crewdually's Avatar
87crewdually
Did you check yet for crank/cam sync? It will start out reading 0 or no then while cranking it should change to 1 or yes. If you have no sync it will not start.
Old May 6, 2016 | 10:06 PM
WatsonR's Avatar
WatsonR
Were they cold logic? 10.5 is ok, any lower, I'd be concerned. What is FICM voltage when it's cold or is the 48v cold and cranking?
How low does main voltage drop to when cranking?
Old May 6, 2016 | 10:14 PM
WatsonR's Avatar
WatsonR
Check the VRef, should be 5v to all sensors. Check one and see what it is. Could be a short and the sensors are not getting voltage to return the reading to the PCM.
