Sponsored by: Real Truck
Battery Help
Old May 6, 2016 | 10:20 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Battery Help
Over the past few weeks, my batteries have been going dead, rather quickly; overnight. I had them tested, and they tested fine (although that day and the day prior, they were doing fine) then a few days later they've died again. I havnt been able to check if there is a drain on the system yet, so last night I disconnected one of the batteries after driving home from work, so I would have one good battery in the morning even if there was a drain. I know the truck will start with just one healthy battery. Welp. No start. That battery was dead too. Can anyone help me figure this out? It's possible that the isolated battery didn't charge long enough on the 5 minute drive home from work, I suppose.
Old May 6, 2016 | 10:48 AM
redford's Avatar
redford
FTE Leadership Emeritus
Are you certain the charging system is functioning properly?
Old May 6, 2016 | 11:14 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Battery Help
I've had it tested twice, and both times it passed. Also, once the truck is on it has no problem holding 13.8-14.0v.
AAA came out this morning after I posted and tested my batteries, and the alternator. The first battery he tested came up at 105CCA of a rated 850CCA. Last week when I had them tested, they tested okay. It seems to be an intermittent issue.
Old May 6, 2016 | 11:52 AM
The John's Avatar
The John
How old are you batteries, did they load test them?
Old May 6, 2016 | 01:47 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
They are a year old. I'm not sure exactly what a load test is. I did a load test today, but I think it was for the alternator? With the truck running he turned on all of the accessories and rev'd the truck and checked voltages.
Old May 6, 2016 | 02:17 PM
phillips91's Avatar
phillips91
Have you checked to make sure there isn't a light on? My step kids are bad about messing with the lights and forgetting to turn them off. They have left my wife with a dead battery on more than one occasion.
Old May 6, 2016 | 05:42 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yes.
Old May 7, 2016 | 07:37 PM
jetjockey99's Avatar
jetjockey99
turning on all the accessories and reving it up and checking voltage is NOT a reliable test, I would not use that person again! A load test puts a large resistive load on the batteries, they should be tested one at a time, not connected together. With the proper equipment you can also accurately load the alternator to check its voltage versus amp output.
Old May 16, 2016 | 11:27 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Both batteries replaced under warranty and have had no problems since.
Klemhineycutt
Jan 9, 2019 08:25 PM
Scoob5555
Dec 12, 2012 01:29 AM
genedwiggins
1997 - 2003 F150
Aug 28, 2011 08:05 PM
snipa
Jun 28, 2008 05:38 PM
mike L
Oct 21, 2005 09:36 PM
