My OBS 7.3L SD Intercooler Install
  #31
Old 05-12-2016, 08:51 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,206 Likes on 829 Posts
Password JDM on my 87nissan 300zx, they blew at 21psi.
  #32
Old 05-12-2016, 09:01 PM
fordman67's Avatar
fordman67
fordman67 is offline
Originally Posted by ceetwarrior
Thanks. I got the IC pipes mocked up today. Although I don't really need to; I'm going to do hump hoses on both sides of the spider to compensate for the odd angles. Fortunately siliconeintakes.com is in my city, so I'll go there tomorrow and pick up the stuff. The driver side is just two pipes, one 45* and one 60*. The passenger side is a tight 90* at IC then 90* then a 60* at the spider. Plently of clearance for dipstick and oil fill with a funnel. I'll get the pipes to my friend to tig up so I'll only have silicone 4 joints.
I wanna do the super duty plastic cover over the fuel filter since the stock isn't going to work anymore.
He is using silicone intakes boots! Just bought the eBay kit for the bends.
Their quality is just fine.
  #33
Old 05-12-2016, 10:13 PM
fordpride's Avatar
fordpride
fordpride is offline
Just a tip on the IC boots. Spray the inside of the boot with the cheapest stickiest hairspray you can find. It helps hold the boots from slipping
  #34
Old 05-13-2016, 07:28 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
And afterwards, you can celebrate with a fireball!
  #35
Old 05-13-2016, 08:09 AM
fordpride's Avatar
fordpride
How ? Been running mine for years like that. Many competition trucks use it to.
  #36
Old 05-13-2016, 08:57 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
But, can you take them apart?
  #37
Old 05-13-2016, 08:59 AM
nateairman's Avatar
nateairman
nateairman is offline
Fireball is pretty stout! One shot otta do...
  #38
Old 05-13-2016, 09:16 AM
ceetwarrior's Avatar
ceetwarrior
ceetwarrior is offline
02 7.3 all aluminum. I don't like plastic and heat. Yum fireball, I think I will. Pipes should be done tomorrow. Then I can post up real pics without JDM **** on my truck, ha
  #39
Old 05-13-2016, 09:40 AM
Jarrett Campbell
Match+hairspray=fun
I wasn't saying it would make the engine into a fireball lol
  #40
Old 05-23-2016, 10:13 AM
mcali2's Avatar
mcali2
mcali2 is offline
Well how did it turn out?
  #41
Old 05-23-2016, 12:16 PM
ceetwarrior
I ended up ordering Riffraff hump hoses since they are longer and would give me the option to double clamp in the future and match my other stuff. My header wrap will be in tomorrow so I'll try my hand at that. I did a Tru-cool 4921-1 trans cooler. I gotta research on the cold weather bypass some more before Colorado winter and decide what to do there. I guess this cooler works so well that it can make the fluid too cold to work correctly. Cardboard? I rubber mounted it to my shackle reversal crossover tube.
I also finally decided on which gauges to get and ordered two of the three for now. I got a lot of work to do before the end of the week to get my truck ready for my desert trip!
  #42
Old 05-23-2016, 12:35 PM
knottyrope's Avatar
knottyrope
knottyrope is offline
get some plastic cardboard from a craft store and you can get it in colors too
  #43
Old 05-24-2016, 12:03 AM
oldbird1965
I tried several times to use my bypass without success. In warm weather it would overheat the trans. Maybe I just had a bad one?
  #44
Old 05-24-2016, 01:03 AM
Kingkong0192's Avatar
Kingkong0192
Kingkong0192 is offline
This. 100x this.
I'm a firm believer in keeping it stupid simple.
I see it (and i could obviously be wrong as this is totally and strictly my opinion) that the bypass, and the blah blah blah is something else to break or malfunction. Transmission too cold? Cover it with cardboard. It can't get simpler and easier than that. I'm sure they have really nice and fancy thermal bypasses but the one that comes with the tru-cooler looks cheap and flimsy and looks like it would restrict the flow of fluid even when it's wide open.
  #45
Old 05-24-2016, 08:52 AM
ceetwarrior
Cool, sounds good. I'll just do the plastic cardboard.
Quick Reply: My OBS 7.3L SD Intercooler Install
