Sponsored by: Real Truck
Wiper Blades
Old May 4, 2016 | 04:16 PM
mattymax's Avatar
mattymax
Wiper Blades
2008 F-350
What size you guys using ? 20 or 22 ?
The book at Walmart is kinda confusing. They have 1999-2008 to use 20" then 2008-2010 to 22 and 2011 and up to use 22" Isn't it all the same windshield after 2008 ?
I got the 20's and I could see that maybe the 22s fit
Thanks
Matt
Old May 4, 2016 | 04:20 PM
seville009's Avatar
seville009
My 2006 F350 takes 20" blades and my 2011 F350 takes 22" blades. If what you have works, use them. There's alot of websites that will give you measurements that you can use to double check the size.
http://mywiperblades.com/2008-ford-f_series_pickup-wipers.htm
Old May 4, 2016 | 04:48 PM
mattymax's Avatar
mattymax
It's funny cause you put in 08 and it calls for 20. And 09 calls for 22. It's the same exact truck
Old May 4, 2016 | 04:50 PM
SXIPro's Avatar
SXIPro
My 2011 calls for 22s but I put on 24s and love them. Bosch Icons.
Old May 4, 2016 | 06:04 PM
Good listener's Avatar
Good listener
I bought a pair of 22" Motorcraft WW-2242 All Season Wiper Blades to replace the OEM blades on my 2015 after a year. The OEM blades are still working great, no reason to change them. They proved themselves better than any other blades I've had in the past, even ones I paid $8 more for. My wife's Fusion has two streak free years on her OEM blades, I'm hoping maybe mine will go that long.
Old May 4, 2016 | 07:07 PM
don123's Avatar
don123
I will buy motorcraft when mine finally fail. The originals perform great at 18k and 1 1/2 years of use.
Old May 4, 2016 | 08:01 PM
darkjedi351's Avatar
darkjedi351
you can fit 24"
Old May 5, 2016 | 03:22 AM
Sam I Am's Avatar
Sam I Am
I am using 24" blades on my 1999 SD with no problems.
Old May 5, 2016 | 03:32 AM
Bently_Coop's Avatar
Bently_Coop
22" on my 99 F250 Super Duty. Windshields and Cabs are the same from 99-16.
I am currently using a RainX low profile blade which works fairly well.
Old May 5, 2016 | 04:46 AM
redford's Avatar
redford
FTE Leadership Emeritus
I use 24s.
Old May 5, 2016 | 01:17 PM
tsedgar's Avatar
tsedgar
Hawkerpilot05
Originally Posted by redford
I use 24s.
Same here, Bosh Icon's.
2005 Ford F250 Crew Cab 5.4l 3 valve
Old May 5, 2016 | 02:45 PM
Rudiak's Avatar
Rudiak
Bosch Icon 24" on my 2008 F250.
Old May 5, 2016 | 08:40 PM
mattymax's Avatar
mattymax
Got 22's today. Not sure how you guys are fitting 24's
Matt
Old May 6, 2016 | 12:06 AM
Bently_Coop
I've seen mentioned the 24" blades hit on an edge.
Old May 6, 2016 | 12:50 AM
vehiclesbreak4me's Avatar
vehiclesbreak4me
I have a 2004 sd and run 24's
