1977 F250 Height
1977 F250 Height
Guys, Need thoughts. I put new rear springs on my 1977 F250. I wanted close to stock height, but looks like it now has way too much Rake in it (about 6"). The measurement from the rear fender to the axle center is about 27". I want to level it back out. I am OK with a little rake, but not that much. Was thinking to put stock highboy springs on it. Will that get me close or do I need more? Aslo what mods do I need to do with steering? Do I need a drop pitman if I take it up to stock highboy height? Anything else to make it right, and reliable?
Just put them on... they maybe have 100 miles on them. I got a set of heavy duty springs with higher rate from a place called Carrier Spring. I did ask them to make them as close to stock as possible with the block removed, but I think they are most definitely higher than stock. Thanks for the reply.
lunar68
16
07-17-2017 04:22 PM
Doc
06-18-2011 01:15 PM
drfordcal
05-16-2011 09:23 PM
73FordF100
03-03-2011 03:36 PM
