My 2000 excursion 12v nv4500
gonna type this up on here and try to add pics from my phone
Last october My colt stage 3 cam went flat.
it only had 18,000 miles on it, i bought it new and installed it correctly, using additive as well.
it started by losing the fuel pump lobe, then followed by the rest.
so i had a 98 12v p pump complete motor i had pulled from another truck sitting and decided to tear it down, send to machine shop and rebuild
they said i had to go .20 over, so i went with all cummins oem internals
went with cummins .20 over big bowl pistons, all new bearings and pins, head was decked and exhaust flange decked as well for flatness
it received hamilton valves, cummins seals, hamilton Beehive springs, and a little polishing
I went with a complet hamilton valvetrain this go around, because colt wouldnt do anything for my situation, i didnt expect them to replace my motor but they wouldnt even give my money back on the cam purchase, needless to say ill never be using them again.
got engine back together and decided on a custom coumpound turbo setup, with a stainless custome header to mount the small turbo up and forward, to allow the s480 to be burried and leave enough room for my hoodstack.
Engine Details:
Bored 20 over
Cummins Big bowl pistons and 20 over rings
cummins oem bearings throughout
ARP studs
Hamilton 165# BeeHive springs
Hamilton Tappets
Hamilton Heavy Duty Pushrods
Hamilton 182/214 Cam
Keating Machine Billet Tappet Cover
Fuel
DFI 5x16 sticks
Stock fuel lines just powder coated Gold
Sump in Factory Tank
FASS titanium 220
180 bosch reman P pump
-191 DV's
-100 plate
-4k Gov springs
-pin timed at 24*
-mack rack plug
-maxed and balanced by farrell diesel service
-Maxed at 500cc of fuel
Air
s363/68/14 waste gated at 40 psi
s480/96/132
both with full 360* thrust bearings
Full custom Flanged Stainless Header
All connections for air are stainless V band Clamps, No boots on whole system
Trans
nv4500
upgraded main shaft
big input shaft/late model
south bend dual disk street 3250
t case is stock ford manual t case with dodge input shaft
plan to add more pics later on,
everything fully functions including A/C except Cruise control,
spare motor that was bored 20 over and is currently in truck
motor that had the colt cam fail
installed a new take off 2015 bumper
ended up re routing these hoses for clearence and heat
full custom stainless header
this is a stock oem cummins piece off of industrial or 4bt aplications, it is a remote oil filter mount, my oil filter is mounted rear of the transmission cross member
laid into it in 5th gear a little too hard i guess and smoked the gear, wasnt a bad fix just had to tear trans completely down and clean the metal out of it, new bearing and syncros, and of course new 5th gear and i was set
next to my girlfriends dads 01 7.3
best friends 16 denali
my 95 5.0 5 speed
