2015 F250 Dome light problems.
Old Apr 26, 2016 | 12:40 PM
fordmustangfan67's Avatar
fordmustangfan67
Hey guys I have a question to ask for a friend of mine. He has been doing some work on his 2015 F250 crew cab XL lately and is having trouble with some of his lights in the cab. Specifically the passenger side reading lights in both front and back. The other lights in both dome lights work just fine.
He had replaced the head unit and ran new cabling to add a couple amps and a sub. After putting things back together he noticed that the underhood light wasn't working as well as the dome lights. Found that a fuse was blown. Fuse #4 in passenger side fuse panel. He replaced it and everything started working again until he would turn on one of the passenger side reading lights. He had replaced the bulbs with led replacements from recon as well in case that matters.
Is their some sort of relay that is not working that would happen to seperate out just those passenger side reading lights? I had him check with a volt meter and he said that he has no voltage to the sockets on the passenger side while he has 12+VDC to the drivers side.
Are these light physically wired differently from side to side? What can he check next?
Thanks for your help!
Old Apr 28, 2016 | 12:28 AM
EO2SeaBee's Avatar
EO2SeaBee
Sorry nobody has been able to provide help to you yet. I vaguely seem to recall that the BCM will detect issues with circuits and shut them down to protect the system, and have to be turned back on using IDS. Of course, I could be way off and am by no means an expert. Hopefully this bump will bring your thread back to the attention of someone better informed. Good luck.
Old Apr 28, 2016 | 12:48 AM
goatram's Avatar
goatram
Might have pinched a wire on reinstallation. Sounds like your friend needs to pull the truck back apart and inspect the wires.
steharmon
2004 - 2008 F150
Aug 14, 2019 08:46 PM
76.0inkd
Aug 19, 2016 12:55 AM
fordmustangfan67
Electrical Systems/Wiring
Apr 29, 2016 06:49 AM
fordmustangfan67
Apr 26, 2016 09:55 PM
vonswedge
Sep 11, 2007 04:19 AM
