Before I commit. Thoughts please
Old Apr 23, 2016 | 11:16 AM
chad77's Avatar
chad77
Hey guys.
Been a while but I'm at the point of welding in the cross members etc. When I measured my original frame from the front to the centerline and I measure 36 1/2".
Does that seem about right with the measurements you have used when installing your cross member?
Any help is greatly appreciated.
Thanks
Old Apr 23, 2016 | 04:30 PM
topmoo's Avatar
topmoo
Bump
What year truck are you working on? Looks like you are building a whole new frame.
Old Apr 23, 2016 | 07:43 PM
chad77's Avatar
chad77
Originally Posted by topmoo
Bump
It's a 56 f100. I was going to put the cross member at 36" on center. Will be using a strut control arm
Old Apr 24, 2016 | 08:22 AM
topmoo's Avatar
topmoo
Looks like really nice work, but I can't help you. Mine is a '52. Someone here I am sure can though...
Old Apr 24, 2016 | 10:25 PM
chad77's Avatar
chad77
I'm probably just going to tack the cross member in place so I can adjust it later if needed.
Old May 1, 2016 | 01:25 PM
petemcl's Avatar
petemcl
I can't tell from the picture but if that is where the rear of trans mounts you may want to bolt it in place from the bottom so that you can service the clutch or remove the trans from the bottom without having to cut your welds once the cab is in place.
Old May 1, 2016 | 02:17 PM
chad77's Avatar
chad77
Mine is the front cross member.
Was also going to do a bolt in for the tranny though.
shipwreck19
Nov 25, 2020 09:29 AM
ingo
Apr 10, 2017 01:30 AM
iwanaflattie
Apr 7, 2014 01:49 PM
sofob0909
Jun 13, 2013 10:19 PM
OldSchoolRodz
Jul 2, 2008 05:04 AM
