NP435 when slowing on downshift
Old Apr 20, 2016 | 10:46 PM
chukar's Avatar
chukar
It's a '74 std cab with the NP435. Acceleration sounds normal, though what would I know, it's the first ford truck of this vintage I've ever owned. But when slowing and especially downshifting into third and then second, it really growls. This normal???
Old Apr 20, 2016 | 10:58 PM
HIO Silver's Avatar
HIO Silver
What do you mean by "growls"?
Old Apr 20, 2016 | 11:06 PM
mountain dewd's Avatar
mountain dewd
You're probably fine. Check the fluid and make sure there is no glitter in the gear oil. 435s are pretty noisy.
Old Apr 21, 2016 | 12:02 AM
chukar's Avatar
chukar
Like there's .25" between the teeth and the space is filled with small pebbles. Just noisier than any trans I've ever heard before. Forward gears all normal sounding.
Drained and replaced gear oil when I first got it home. Nothing in the oil that drained out that looked suspicious.
Old Apr 21, 2016 | 08:30 AM
shanes66charger's Avatar
shanes66charger
could have a bearing tore out in it......but they're pretty bulletproof generally.....hard to know without hearing it
Old Apr 21, 2016 | 09:56 AM
ZarK-eh's Avatar
ZarK-eh
I'd pull the top off and check things out. Should be easy while still in the truck.
can0fspam
Aug 16, 2018 02:30 PM
roadrash63
Sep 24, 2012 06:20 PM
sawyersvintage
Aug 12, 2011 07:19 PM
870
15
Apr 17, 2007 07:03 PM
bjoern
Dec 26, 2001 09:59 AM
