flathead 6 start, what to do next
Old Apr 18, 2016 | 10:19 AM
rusty48's Avatar
rusty48
Hi all, picked up an old 48 with what I believe is a 226 flathead 6. Been toying with starting it for the last few weekends. Is 6v, decent plugs and wires, has spark, bypassed fuel system, with small tank to the carb. It cranks, hits, backfires back through carb and that's about it.
Went ahead and did a dry compression test, then added 2 tablespoons of MMO and here are the results all plugs removed.
60, 45, 0, 30, 75, 65
after MMO 60, 55,0, 40, 80,70
I believe intake valve on #3 is stuck so left it overnight and currently recharging 6v. I have bumped starter with 12v, having cleaned up all 6v, cranks ok and about the same.
What next, ??????????
Old Apr 18, 2016 | 11:38 AM
Mixer man's Avatar
Mixer man
Well you definitely have some sad rings, and I suspect a valve too. I had a similar situation, and my next move was to pull the head.
Old Apr 18, 2016 | 11:46 AM
rusty48's Avatar
rusty48
I sprayed head bolts with the break free last night preparing for the next step, Im guessing a full rebuild is in my future??? just wanted to exhaust all possibilities prior to surgery.
Old Apr 18, 2016 | 12:23 PM
Mixer man's Avatar
Mixer man
Depending on how your crank and bearings check out you may only need a top end o'haul. Did it have good oil pressure?
Old Apr 18, 2016 | 01:57 PM
76-5.0's Avatar
76-5.0
Similar story here, 48 226, sat for 10 years behind my shop. Pulled the head and inspected, oiled all valves and made sure they were free. My sons and I replaced the head gasket and got it to fire off and run. After running it a few times we rechecked compression and the cylinders evened out as the rings freed up. We got lucky as there was no rust in the cylinders with open valves during it's 10 year rest. Good luck!
Old Apr 18, 2016 | 02:00 PM
raytasch's Avatar
raytasch
Believe Nothing
It is going to be hard to start with those low compression figures. You may get it to spin fast enough to build a bit more compression and start by feeding 12V across the starter directly. This will allow the six volt ignition to have hotter spark as well.
Old Apr 18, 2016 | 02:22 PM
arctic y block's Avatar
arctic y block
Try to pull start it if you can.
Old Apr 18, 2016 | 03:25 PM
rusty48's Avatar
rusty48
gauge cluster is a rats nest, so no oil pressure info. brakes are all but not existent so pulling not advisable. Basically hot wiring to the coil
We did put 12v to the starter, with jumper cables seemed to crank about the same as the 6 v. Cables got worm, 15 feet might be too long to get much bang.
Also a side question, the rotor seems to have a full hour of play? Diff seems fine, its an American rotor, just seems like too much??
Old Apr 18, 2016 | 03:49 PM
Mixer man's Avatar
Mixer man
Most likely the jumper cables are way undersized.
Are your centrifugal advance springs broken in the distributor?
areoseek
51
Nov 14, 2013 08:22 PM
48 to 49er
Oct 29, 2013 12:23 AM
halaferd
31
Oct 9, 2011 11:50 PM
brain75
41
Oct 3, 2011 09:35 AM
nataneely
22
Dec 6, 2008 07:59 PM
