Question regarding ground straps
Old Apr 17, 2016 | 11:06 PM
animator's Avatar
animator
Crawling around under the truck and noticed something that looked out of place... I have a ground strap that runs from the body to the frame located just under the passenger footwell. The strap connects to the body mount from the frame under the passenger side, and then runs up to the pinch weld under the cab just above it.
Can anyone confirm if this is a factory-installed ground strap? It just looks out of place to me.
I don't have any brake controllers or anything inside the cab that didn't come from the factory. There was what appeared to be a car phone amplifier or something located behind the seat on the driver side, with one of those old-school cell phone antennas attached to the rear window, but that and the associated wiring has been removed...
I can't think of a reason for that ground strap to be there unless it came that way from the factory, which would seam odd.
Old Apr 18, 2016 | 09:26 AM
JohnPaulRome's Avatar
JohnPaulRome
My '95 xl has that strap also. I think it's stock. Sandpaper the metal where it connects. All of the grounds are important.
Old Apr 18, 2016 | 09:59 AM
Diesel_Brad's Avatar
Diesel_Brad
That is a factory piece
Old Apr 18, 2016 | 12:48 PM
subford's Avatar
subford
It is put there to keep static out of the radio.
It has no electrical grounding purpose as the frame is not a ground point unless you pull a trailer.
It is called a static electricity ground strap. You should also have some more of them in the radiator area and one between the engine and the safety wall (fire wall).
cranegrad
Sep 23, 2016 08:19 AM
FordIowan
Oct 21, 2012 04:57 PM
johaner78
Jan 5, 2011 07:53 PM
Eric H
Sep 26, 2009 06:10 PM
teederj2002
Aug 13, 2003 09:52 PM
