Gassed up
Old Apr 17, 2016 | 05:21 PM
Vinford's Avatar
Vinford
Gassed up
So I put 111 Liters of gas in my 6L today.
So whats the procedure, Ive sucked most of the gas out of the tank.
Ive never changed filters on this truck myself but , is there one under truck and one on top of engine?
Old Apr 17, 2016 | 05:40 PM
69cj's Avatar
69cj
Did you start the truck??
Old Apr 17, 2016 | 05:48 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Drop the tank entirely and clean it out, it'll hold several gallons down in the bottom. If you didn't start it I'd flush the lines from the HFCM back to the tank out.
Fuel filter guide:
Old Apr 17, 2016 | 06:53 PM
Vinford's Avatar
Vinford
I started it and drove 5 miles.
Theres about 10L of gas left in the tank , you don't think I could fill it back up with diesel and drive it?
Old Apr 17, 2016 | 07:10 PM
69cj's Avatar
69cj
IMO you need to drain the tank change the filters and when the top filter is out fill it with PM22. Main object is to not damage injectors at this point.
Old Apr 17, 2016 | 07:30 PM
Vinford's Avatar
Vinford
At this point taking the tank out is not a option Ill let you know how it goes lol.
Ive got most of the gas out of the tank am working on draining filters , am going to fill it back up with diesel and give it a go ......................
Old Apr 17, 2016 | 08:18 PM
navistarnut's Avatar
navistarnut
Just be sure to add extra lube of some sort, Optilube.....PM22.........I think your best bet is Optilube XL Extreme....gas will dry out things out. The XL is some slippery stuff, not sure a cetane booster is the way to go, gas is volatile enough the way it is, not need to risk extra detonation.
Old Apr 17, 2016 | 09:09 PM
Vinford's Avatar
Vinford
Did and done thank you.
Old Apr 17, 2016 | 09:10 PM
Vinford's Avatar
Vinford
She runs great thanks for the help guys.
Old Apr 17, 2016 | 09:14 PM
Per4mance's Avatar
Per4mance
Run 2 oz 2 stroke to the gallon,will help cushion the injectors from the gas.
thesnowboarder
21
Sep 28, 2012 09:12 AM
Jared17
Jul 17, 2012 11:12 AM
DAVID'S97F250HD
18
Mar 19, 2008 03:18 AM
EpicCowlick
Dec 30, 2007 06:14 PM
tp
Feb 12, 2004 11:30 PM
