302 EFI C6 kick-down help
Old Apr 26, 2016 | 06:16 PM
Gary Lewis's Avatar
Gary Lewis
Yes, I am. But, it looks like it may not get here - although it is likely to get YOU. Are you ready?
Old Apr 26, 2016 | 06:33 PM
the okie's Avatar
the okie
Trailering
It looks like if I make it to about 9:30 i'll know if I was.
Old Apr 26, 2016 | 06:42 PM
Gary Lewis's Avatar
Gary Lewis
In our case it'll start about 9:30.
Old Apr 26, 2016 | 08:55 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
9A758 is the accelerator cable.
7F042 is the throttle control cable. With 302/EFI .. it's only listed for AOT (see lower pic for applications).
Old Apr 26, 2016 | 09:45 PM
the okie's Avatar
the okie
Trailering
Bill,I found this on the on the 87-96 FTE.Ikmow I have a c6 but it looks like they used this for the aod too.
My next question is what controls kick-down? (SOLVED)
Old Apr 27, 2016 | 03:01 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Not sure if this is helpful or not but I just went through trying to get a kickdown cable for my 88 F150 302efi w/C6 (mine was frayed really bad). There from what I found none that hook up the same for the efi style. You will have to find one in the junkyard.
The kickdown cable has its self adjustment set up which a lot of times don't work the best. I ended up adjusting it around till it felt right after driving it not sure if you guys know a better way of adjusting it then the way I read.
Trav
Old May 1, 2016 | 09:51 AM
85MOTORSPORTXLT's Avatar
85MOTORSPORTXLT
Well that's gonna be a challenge, most of that stuff is getting crushed.
Old May 2, 2016 | 09:44 AM
86fn150's Avatar
86fn150
a converted to efi a few years ago. with carb the c6 kickdown lever is pushed down to kickdown but efi cable pulls it.i reversed the lever on trans to pull motion and needed to add a ball stud instead of flat clip style on end of it.you might be able to find a core from newer truck with correct setup
1989f1504x4
Jun 21, 2015 11:35 PM
tominator
Jan 2, 2004 06:56 PM
cbwarrior
Nov 24, 2002 09:18 AM
paveslave
Aug 5, 2002 04:27 PM
