There isn't any pump in the tank on these. Just the one under the drivers seat in the frame rail. Comes on for about 15 secs give or take when you turn the key on then shut off if you dont crank the truck. IPR is just below the fuel bowl on drivers side. Looking for a pic now
Also while you looking at things check the wire harness at the square 42 pin connector were it crosses the driver side valve cover. Many have found worn through wires. see pics. Not sure if it will cause a complete cut out but could depending on which wire is rubbed through
Ok I looked at the wiring going to the ipr and it looks ok. The tin nut on the end is tight. When I grab the wiring harness for the ipr I can wiggle the sensor inside the housing. Is that normal? Is 15 seconds a normal amount of time for the fuel bowl to be filled? There is a line going from the bottom of the fuel bowl on the passenger side that runs behind the passenger valve cover. In the back it is covered in oil. Is that a high pressure oil line or fuel line?
Ok, mam this is a really crazy problem. Everything has checked out good. Can I check oil and fuel pressure with the conventional guages? I don't know what else it could be. It couldn't be an issue with the ignition switch could it?
I'm leaning toward a thermal intermittent problem with the IPR coil, myself. Could be other things, but the symptoms are in line with it. That's why I suggested hooking up a CFR and capturing it when it happens. If that's it, it should be pretty obvious in the ICP and IPR data. Another thing you could try in the meantime is drive it until it dies, then cool the IPR coil with some ice water. If it restarts immediately, that's most likely the issue.
You can check fuel pressure with a mechanical gauge, but it requires a -4 ORB adapter for the fittings on the filter housing. Or there's an 1/8" NPT port on each head, but they're kind of a a pain to get to.
Passenger side wheel well has a drain pipe (3/8" od) Connect a rubber tube to this and to a fuel pressure gauge. Open fuel filter drain valve on back side of filter. Start truck. Tape or tie the gauge to the radio antenna so you can watch fuel pressure while driving.
Larry
Larry
The problem with that is normally there are no clamps on the rubber section between the drain valve and the metal tube.
