Oil Dipstick replacement
Old Apr 15, 2016 | 04:00 PM
Kayaken's Avatar
Kayaken
My 1990 E-150 w/ 5.0 Dipstick rusted out.
Everyone's trying to sell me a 27" one. But the old one is 33" .
Does any one have a source for the correct size?
Even the dealer doesn't have/can't get one?
Old Apr 15, 2016 | 05:20 PM
annaleigh's Avatar
annaleigh
Is the dipstick or the tube rusted out?
<table class="m_pl_table" height="81" width="422"><tbody><tr class=""><td class="m_pl_number">
</td> <td class="m_pl_desc td"> Indicator Assy - Oil Level
Fit Note: 5.0Cyl Callout Name: 6750
Part Number: FOUZ-6750-D
</td></tr></tbody></table><table class="m_pl_table" height="136" width="894"><tbody><tr class=""><td class="m_pl_number">
</td> <td class="m_pl_desc td"> Tube - Oil Level Indicator
Fit Note: 5.0 8 Cyl
Callout Name: 6754
E6UZ-6754-A
If it is the tube you need. Notice the part number starts with E =1980's, 6= they actual year, hence 1996.
U stands for = Econoline So the part was built for a 1986 econoline.
This guy has the correct part number but gives a different fitment from what the part number belongs to
http://www.ebay.ca/itm/FORD-OEM-92-9...RWYCwC&vxp=mtr
Just double checked and according to FPG list, that part number is good for a e150 with a 5.0 from 1986 to 1996
Old Apr 15, 2016 | 06:17 PM
Kayaken's Avatar
Kayaken
E-150 dipstick
The tube seems fine. The dipstick rusted out at the top. I had the same problem with my 79 F-150. Condensation acumulates at the top.
Thanks for the info!
Old Apr 15, 2016 | 08:38 PM
annaleigh's Avatar
annaleigh
well I think you will have a hard time finding the dipstick itself unless you go to a junk yard.. I was thinking about materials one could make one out of.. I dont know if Nylon would hold up but HF sells a nylon fish tape pretty cheap and it is quite flexiable.
Nylon Fish Tape - Save Big on this 50 Ft. Nylon Fish Tape
You can also buy stainless steel braided cable and make an end for it as well as figure out a way to fasten it to the dipstick handle.
You might be able to find a transmission dipstick and cut it to length and adapt it to your old handle.
Or you might try a place that makes dipsticks
http://www.rbroyal.com/products/oil-dipsticks-tubes
Or take a look at this one and see if you can modify it..
Length (In): 67.600 Inch
http://www.oreillyauto.com/site/c/de...7308/03013.oap
Contact this seller and get him to measure this one, maybe you could modify it..
http://www.ebay.com/itm/04-10-Ford-E...VWxioH&vxp=mtr
Old Apr 15, 2016 | 09:46 PM
Kayaken's Avatar
Kayaken
Thanks for the insight.
I'll start checking junkyards. But cutting a longer one down is probably the way to go. Luckly, it broke while pulling it out, so it's not stuck down the tube.
big ole ford
Aug 9, 2019 03:39 AM
jwitty
May 3, 2019 12:40 PM
james70
16
Nov 23, 2017 03:04 PM
messymom
Jan 30, 2015 04:36 PM
bigtexan99
Aug 13, 2012 10:02 AM
